Can't upload code to Arduino Uno
I just can’t seem to upload my code. Whenever I try I get this error code:
Processing uno (platform: atmelavr; board: uno; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (5.0.0) > Arduino Uno
DEBUG: Current (avr-stub) External (avr-stub, simavr)
 - framework-arduino-avr @ 5.2.0
 - tool-avrdude @ 1.60300.200527 (6.3.0)
Found 6 compatible libraries
Linking .pio/build/uno/firmware.elf
.pio/build/uno/src/Blink.cpp.o (symbol from plugin): In function `setup':
(.text+0x0): multiple definition of `setup'
.pio/build/uno/src/AlternatingLights.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `loop'
.pio/build/uno/src/BlinkSerial.cpp.o (symbol from plugin): In function `setup':
.pio/build/uno/src/SerialLedSwitch.cpp.o (symbol from plugin): In function `setup':
.pio/build/uno/src/SingleBlink.cpp.o (symbol from plugin): In function `setup':
*** [.pio/build/uno/firmware.elf] Error 1
======================================= [FAILED] Took 0.80 seconds =======================================
 *  The terminal process "platformio 'run', '--target', 'upload', '--environment', 'uno', '--upload-port', '/dev/cu.usbmodem101'" terminated with exit code: 1.
Please help!
Hi @clemesbot1
For better readability I edited your post and used pre-formatted text for code and log sections.
The error message says:
You have multiple setup() and multiple loop() functions in multiple .cpp files in your project, namely
  • Blink.cpp
  • AlternatingLights.cpp
  • BlinkSerial.cpp
  • SerialLedSwitch.cpp
  • SingleBlink.cpp
This is invalid.
You can just have one setup() and one loop() function in one .cpp file.
Usually you have a main.cpp where setup() loop() and loop are implemented.
Wait, but they are different codes in different files. I need multiple so that all the codes work. I need to make a new folder for each new file?
Are this different projects?
Then you need to create different projects. One for each file.
