You’re right. Follow your prompts, I use another computer to run the program, and get “JTAG config starting. Found a device” immediately.
Maybe I installed so many softwares in my computer for compiling avarice a few days ago, and there are some conflicts. These conflicts affect the use of avarice.
I have to reinstall the OS immediately, see you later.
Even got SVD files for teh ATMega chips so that the “Peripherals” view can decode the peripheral registers. After changing LED Pin (PB5) to output, the PORTB peripheral has changed values
Thank you for your great work.
Can you give the Platformio team a suggestion: let the Platformio fully support the board, uploading and debugging easily.
Best regards.
