Thank you for your answer.
First the platformio.ini:
Then the error:
Processing Arduino mega 2560 (board: megaatmega2560; platform: atmelavr; framework: arduino)
----------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/megaatmega2560.html
PLATFORM: Atmel AVR (3.4.0) > Arduino Mega or Mega 2560 ATmega2560 (Mega 2560)
- framework-arduino-avr 5.1.0
Found 12 compatible libraries
|-- <LiquidCrystal> 1.0.7
|-- <Adafruit BusIO> 1.8.2
| |-- <Wire> 1.0
| |-- <SPI> 1.0
|-- <Adafruit MCP9600 Library> 1.1.2
| | |-- <Wire> 1.0
| | |-- <SPI> 1.0
| |-- <Wire> 1.0
| |-- <SPI> 1.0
|-- <Button>
|-- <PressureControl>
|-- <TemperatureControl>
|-- <LaminatorTimer>
|-- <Wire> 1.0
Compiling .pio\build\Arduino mega 2560\src\buttonsState.cpp.o
Compiling .pio\build\Arduino mega 2560\src\laminationProcess.cpp.o
Compiling .pio\build\Arduino mega 2560\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\Arduino mega 2560\libFrameworkArduino.a
Linking .pio\build\Arduino mega 2560\firmware.elf
C:\Users\bothr\AppData\Local\Temp\cca5HHcC.ltrans0.ltrans.o: In function `main':
<artificial>:(.text.startup+0x2d0): undefined reference to `processState'
<artificial>:(.text.startup+0x2d4): undefined reference to `processState'
<artificial>:(.text.startup+0x2d8): undefined reference to `timerState'
<artificial>:(.text.startup+0x35a): undefined reference to `processStates()'
<artificial>:(.text.startup+0x360): undefined reference to `processState'
<artificial>:(.text.startup+0x364): undefined reference to `processState'
*** [.pio\build\Arduino mega 2560\firmware.elf] Error 1
============================== [FAILED] Took 7.66 seconds ==============================
And the code. My code is made of the main and several sub-function:
The main.ccp:
// Sub-functions
#include <headers.hpp>
#include <laminationProcess.hpp>
#include <processStates.hpp>
// set up the LCD's number of columns and rows:
lcd.begin(20, 4);
buttonsInit();
processInit();
bottomChamberTemperature.init();
topChamberPressure.init();
bottomChamberPressure.init();
// check the buttons status
buttonsRun();
// Process statement
processStates();
// Process definition
laminationProcess ();
bottomChamberTemperature.run();
topChamberPressure.run();
bottomChamberPressure.run();
processStates.hpp:
#ifndef _H_PROCESS
#define _H_PROCESS
// #include <librairies.hpp>
//int state;
extern String statusName;
extern int remaningTime;
extern int nextStepTime;
void processInit();
void processStates();
processStates.cpp:
#include <processParameters.hpp>
#include <laminatorLCD.hpp>
void processInit() {
processState = 1;
timerState = 0;
void procesStates() {
if (processState == 1) {
statusName = "preheating";
if (bottomChamberTemperature.readTemperature() >= processTemp) {
lcdPrint(6);
else {
lcdPrint(4);
if (startButton.state == HIGH) {
if(bottomChamberPressure.test() == 1) {
processState = 2;
else if (bottomChamberPressure.test() == 0) {
lcdPrint(8);
if (processState == 2) {
statusName = "gluing";
lcdPrint(5);
if (bottomChamberPressure.readPressure() <= gluingPressure) {
processState = 3;
if (processState == 3) {
statusName = "post gluing";
if (bottomChamberPressure.readPressure() >= 0) {
processState = 4;
if (processState == 4) {
statusName = "air vacuuming";
lcdPrint(1);
if (bottomChamberPressure.readPressure() <= vacuumPressure && timerState == 0) {
time0 = millis();
timerState = 1;
if (millis() >= time0 + vacuumDelay * 1000 * 60) {
processState = 5;
topChamberPressure.setInitialTime((millis() - time0) * 1000);
timerState = 0;
nextStepTime = vacuumDelay - (millis() - time0) * 1000 * 60;
if (processState == 5) {
statusName = "lamination 1/3";
lcdPrint(1);
if (timerState == 0) {
time1 = millis();
timerState = 1;
if (millis() >= time1 + push1Delay * 1000 * 60) {
processState = 6;
timerState = 0;
nextStepTime = push1Delay - (millis() - time1) * 1000 * 60;
if (processState == 6) {
statusName = "lamination 2/3";
lcdPrint(1);
time2 = millis();
timerState = 1;
if (millis() >= time2 + push2Delay * 1000 * 60) {
processState = 7;
timerState = 0;
nextStepTime = push2Delay - (millis()-time2) * 1000 * 60;
if (processState == 7) {
statusName = "lamination 3/3";
lcdPrint(1);
time3 = millis();
timerState = 1;
if (millis() >= time3 + push3Delay * 1000 * 60) {
processState = 8;
timerState = 0;
nextStepTime = push3Delay - (millis() - time3) * 1000 * 60;
if (processState == 8) {
statusName = "back to atmo. pressure";
processState = 1;
remaningTime = vacuumDelay + push1Delay + push2Delay + push3Delay - (millis() - time0) * 1000 * 60;
headers.hpp:
#ifndef _H_HEADERS
#define _H_HEADERS
#include <arduinoPins.hpp>
#include <TemperatureControl.hpp>
#include <PressureControl.hpp>
#include <Button.hpp>
#include <LiquidCrystal.h>
#include <buttonsState.hpp>
// Define I2C address
const int i2c_temp_mat = 0x67;
extern unsigned long time0; // value of millis() when the vacuum is reach for the first time
extern unsigned long time1; // value of millis() when the firt push start
extern unsigned long time2; // value of millis() when the second push start
extern unsigned long time3; // value of millis() when the third push start
extern bool timerState;
extern int processState;
// initialize the library by associating any needed LCD interface pin
// with the Arduino pin number it is connected to
const int rs = 11, en = 12, d4 = 2, d5 = 3, d6 = 4, d7 = 5; // ATTENTION !!! CES VALEURS LA CORESPONDENT A L'ARDUINO UNO
static LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
static TemperatureControl bottomChamberTemperature(HEATER_PIN, TEMPERATURE_PIN);
static PressureControl topChamberPressure(VACUUM_TOP_PIN, ATMOSPHERIC_TOP_PIN, PRESSURE_TOP_PIN);
static PressureControl bottomChamberPressure(VACUUM_BOTTOM_PIN, ATMOSPHERIC_BOTTOM_PIN, PRESSURE_BOTTOM_PIN);
static Button startButton(START_BUTTON_PIN, START_LED_PIN);
static Button stopButton(STOP_BUTTON_PIN, STOP_LED_PIN);
static Button parametersButton(PARAMETERS_BUTTON_PIN);
Tell me if anything is missing.
