Hello everybody
I’m working on a project on STM32 in Ada language that calls a C library developped on C/C++ with PlatformIO and Arduino Framework.
It works when I don’t use the functions of Arduino framework : I tested with a simple add() function : build and link were ok with the object code .pio\build\nucleo_f446re\src\export.c.o that contains the function (build and link on GNAT Studio Ada environment and the test was ok on a nucleo F446RE)
But when I use functions of Arduino framework (digitalWrite and delay) I’ve got “undefined reference” linking errors.
I’ve linked with .pio\build\nucleo_f446re\libFrameworkArduino.a
This library is recognized by the linker (error messages references it) but it seems not enough to link
Thanks for your help
The object code and libraries on PIO :
And the linking error messages :
gprbuild --target=arm-eabi -d -PC:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_ada\test_librairie_c_code_ada.gpr -XADL_BUILD_CHECKS=Disabled -XADL_BUILD=Debug -XADAFLAGS= -largs -Wl,-Map=map.txt
Link
[link] test_librairie_c_code_ada.adb
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: C:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_c\.pio\build\nucleo_f446re\libFrameworkArduino.a(wiring_digital.c.o): in function `pinMode':
wiring_digital.c:(.text.pinMode+0x36): undefined reference to `pin_in_pinmap'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_digital.c:(.text.pinMode+0x3e): undefined reference to `dac_stop'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_digital.c:(.text.pinMode+0x88): undefined reference to `pin_in_pinmap'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_digital.c:(.text.pinMode+0x92): undefined reference to `pwm_stop'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_digital.c:(.text.pinMode+0xc8): undefined reference to `digitalPin'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_digital.c:(.text.pinMode+0xd0): undefined reference to `PinMap_DAC'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_digital.c:(.text.pinMode+0xd4): undefined reference to `analogInputPin'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_digital.c:(.text.pinMode+0xd8): undefined reference to `PinMap_TIM'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_digital.c:(.text.pinMode+0xa0): undefined reference to `pin_function'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_digital.c:(.text.pinMode+0xc0): undefined reference to `_Error_Handler'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: C:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_c\.pio\build\nucleo_f446re\libFrameworkArduino.a(wiring_digital.c.o): in function `digitalWrite':
wiring_digital.c:(.text.digitalWrite+0x64): undefined reference to `digitalPin'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_digital.c:(.text.digitalWrite+0x68): undefined reference to `GPIOPort'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_digital.c:(.text.digitalWrite+0x6c): undefined reference to `pin_map_ll'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_digital.c:(.text.digitalWrite+0x70): undefined reference to `analogInputPin'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: C:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_c\.pio\build\nucleo_f446re\libFrameworkArduino.a(wiring_digital.c.o): in function `digitalRead':
wiring_digital.c:(.text.digitalRead+0x64): undefined reference to `digitalPin'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_digital.c:(.text.digitalRead+0x68): undefined reference to `GPIOPort'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_digital.c:(.text.digitalRead+0x6c): undefined reference to `pin_map_ll'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_digital.c:(.text.digitalRead+0x70): undefined reference to `analogInputPin'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: C:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_c\.pio\build\nucleo_f446re\libFrameworkArduino.a(wiring_digital.c.o): in function `digitalToggle':
wiring_digital.c:(.text.digitalToggle+0x6c): undefined reference to `digitalPin'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_digital.c:(.text.digitalToggle+0x70): undefined reference to `GPIOPort'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_digital.c:(.text.digitalToggle+0x74): undefined reference to `pin_map_ll'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_digital.c:(.text.digitalToggle+0x78): undefined reference to `analogInputPin'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: C:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_c\.pio\build\nucleo_f446re\libFrameworkArduino.a(wiring_time.c.o): in function `millis':
wiring_time.c:(.text.millis+0x0): undefined reference to `getCurrentMillis'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: C:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_c\.pio\build\nucleo_f446re\libFrameworkArduino.a(wiring_time.c.o): in function `micros':
wiring_time.c:(.text.micros+0x0): undefined reference to `getCurrentMicros'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: C:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_c\.pio\build\nucleo_f446re\libFrameworkArduino.a(wiring_time.c.o): in function `delay':
wiring_time.c:(.text.delay+0x6): undefined reference to `getCurrentMillis'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_time.c:(.text.delay+0x10): undefined reference to `getCurrentMillis'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: C:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_c\.pio\build\nucleo_f446re\libFrameworkArduino.a(wiring_analog.c.o): in function `analogReadResolution':
wiring_analog.c:(.text.analogReadResolution+0x32): undefined reference to `_Error_Handler'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: C:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_c\.pio\build\nucleo_f446re\libFrameworkArduino.a(wiring_analog.c.o): in function `analogWriteResolution':
wiring_analog.c:(.text.analogWriteResolution+0x1c): undefined reference to `_Error_Handler'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: C:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_c\.pio\build\nucleo_f446re\libFrameworkArduino.a(wiring_analog.c.o): in function `analogRead':
wiring_analog.c:(.text.analogRead+0xe): undefined reference to `adc_read_value'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: C:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_c\.pio\build\nucleo_f446re\libFrameworkArduino.a(wiring_analog.c.o): in function `analogWrite':
wiring_analog.c:(.text.analogWrite+0x24): undefined reference to `pin_in_pinmap'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_analog.c:(.text.analogWrite+0x90): undefined reference to `pin_in_pinmap'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_analog.c:(.text.analogWrite+0x104): undefined reference to `digitalPin'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_analog.c:(.text.analogWrite+0x108): undefined reference to `PinMap_DAC'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_analog.c:(.text.analogWrite+0x114): undefined reference to `analogInputPin'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_analog.c:(.text.analogWrite+0x118): undefined reference to `PinMap_TIM'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_analog.c:(.text.analogWrite+0x66): undefined reference to `dac_write_value'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: wiring_analog.c:(.text.analogWrite+0xd4): undefined reference to `pwm_start'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: C:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_c\.pio\build\nucleo_f446re\libFrameworkArduino.a(pins_arduino.c.o): in function `pinNametoDigitalPin':
pins_arduino.c:(.text.pinNametoDigitalPin+0x2c): undefined reference to `digitalPin'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: C:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_c\.pio\build\nucleo_f446re\libFrameworkArduino.a(pins_arduino.c.o): in function `analogInputToPinName':
pins_arduino.c:(.text.analogInputToPinName+0xec): undefined reference to `analogInputPin'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: pins_arduino.c:(.text.analogInputToPinName+0xf0): undefined reference to `digitalPin'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: C:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_c\.pio\build\nucleo_f446re\libFrameworkArduino.a(pins_arduino.c.o): in function `digitalpinIsAnalogInput':
pins_arduino.c:(.text.digitalpinIsAnalogInput+0x24): undefined reference to `analogInputPin'
c:/users/mbdj/.config/alire/cache/dependencies/gnat_arm_elf_12.2.1_351564ba/bin/../lib/gcc/arm-eabi/12.2.0/../../../../arm-eabi/bin/ld.exe: C:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_c\.pio\build\nucleo_f446re\libFrameworkArduino.a(pins_arduino.c.o): in function `digitalPinToAnalogInput':
pins_arduino.c:(.text.digitalPinToAnalogInput+0x34): undefined reference to `analogInputPin'
gprbuild: link of test_librairie_c_code_ada.adb failed
gprbuild: failed command was: c:\users\mbdj\.config\alire\cache\dependencies\gnat_arm_elf_12.2.1_351564ba\bin\arm-eabi-gcc.exe test_librairie_c_code_ada.o b__test_librairie_c_code_ada.o C:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_ada\obj\development\package_test_librairie_c_code_ada.o C:\Users\mbdj\Dev\AdaLib\Ada_Drivers_Library-master\boards\nucleo_f446re\obj\full_lib_Debug\libada_drivers_library.a C:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_c\.pio\b
uild\nucleo_f446re\src\export.c.o C:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_c\.pio\build\nucleo_f446re\libFrameworkArduino.a -Wl,-Map=map.txt -LC:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_ada\obj\development\ -LC:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_ada\obj\development\ -LC:\Users\mbdj\Dev\AdaLib\Ada_Drivers_Library-master\boards\nucleo_f446re\obj\full_lib_Debug\ -LC:\users\mbdj\.config\alire\cache\dependencies\gnat_arm_e
lf_12.2.1_351564ba\arm-eabi\lib\gnat\embedded-stm32f4\adalib\ -static-libgcc C:\users\mbdj\.config\alire\cache\dependencies\gnat_arm_elf_12.2.1_351564ba\arm-eabi\lib\gnat\embedded-stm32f4\adalib\libgnarl.a C:\users\mbdj\.config\alire\cache\dependencies\gnat_arm_elf_12.2.1_351564ba\arm-eabi\lib\gnat\embedded-stm32f4\adalib\libgnat.a -Wl,-LC:\users\mbdj\.config\alire\cache\dependencies\gnat_arm_elf_12.2.1_351564ba\arm-eabi\lib\gnat\embedded-stm32f4\/adalib -nostartfiles -nolibc -Wl,--start-group,-l
gnarl,-lgnat,-lc,-lgcc,--end-group -LC:\users\mbdj\.config\alire\cache\dependencies\gnat_arm_elf_12.2.1_351564ba\arm-eabi\lib\gnat\embedded-stm32f4\/ld_user -LC:\users\mbdj\.config\alire\cache\dependencies\gnat_arm_elf_12.2.1_351564ba\arm-eabi\lib\gnat\embedded-stm32f4\/ld -mlittle-endian -mfloat-abi=hard -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mthumb -T common-ROM.ld -o C:\Users\mbdj\Dev\Ada\STM32\test_librairie_c\test_librairie_c_code_ada\bin\\test_librairie_c_code_ada
[2023-08-12 11:42:47] process exited with status 4, 100% (183/183), elapsed time: 01.13s
