Old thread, but still not solved ( I’ve done other things for a while ).
REFRESH,
I have a ESP32-DevKitC-S1 board from Espressif. It contains ESP32-SOLO-1 which is a stripped down ESP32 module (Just one core )
I cant get it to work.
My configuration.
[env:esp-wrover-kit]
board = esp-wrover-kit
build_flags = -DCONFIG_FREERTOS_UNICORE=1
My code:
delay(500);
Serial.print(".");
The terminals shows following during upload process:
Building .pioenvs\esp-wrover-kit\firmware.bin
DATA: [ ] 4.3% (used 14012 bytes from 327680 bytes)
PROGRAM: [== ] 16.6% (used 217640 bytes from 1310720 bytes)
AVAILABLE: esp-prog, esptool, ftdi, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm- ......
Looking for upload port...
Auto-detected: COM4
Uploading .pioenvs\esp-wrover-kit\firmware.bin
Serial port COM4
Connecting.......
Chip is ESP32D0WDQ5 (revision 1)
Features: WiFi, BT, Single Core
MAC: 24:0a:c4:85:cd:f4
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 15088 bytes to 9755...
Wrote 15088 bytes (9755 compressed) at 0x00001000 in 0.1 seconds (effective 1058.8 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 144...
Wrote 3072 bytes (144 compressed) at 0x00008000 in 0.0 seconds (effective 3510.9 kbit/s)...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 13107.5 kbit/s)...
Compressed 217776 bytes to 102879...
Wrote 217776 bytes (102879 compressed) at 0x00010000 in 1.7 seconds (effective 1005.3 kbit/s)...
Leaving...
Hard resetting via RTS pin...
The monitor shows the following:
Executing task in folder Test: C:\.platformio\penv\Scripts\platformio.exe device monitor <
--- Miniterm on COM4 115200,8,N,1 ---
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:952
load:0x40078000,len:6084
load:0x40080000,len:7944
entry 0x40080310
Output window shows the following:
Error: no handler found
The only thing I think is strange is ( during upload process )
Leaving...
So, anyone who can help ??
