I have the same problem with those annoying “Error: no handler found” messages.
They appear in Task Window of Visual Studio Code.
The output of the ESP32 board is shown correctly in the Terminal Windows.
So the error does not seem to affect anything, but is annoying.
The error shows up everytime i start a Build Task or a Upload Task in Visual Studio Code while Platformio IDE is loaded.
I tried a reinstall of VSC and Platformio, but the error persists.
On another machine with the same code the error does not show up.
… so the recommendation here is if I want to use the Arduino framework on a single core ESP32, I must first rebuild the Arduino framework with the menuconfig set to single core? Is there a plan to support single core ESP32 devices in the Arduino framework?
Not for me. I’ve tried both setting “CONFIG_FREERTOS_UNICORE=y” in the arduino sdkconfig file. I edited the file located here (I’m on windows 10):
C:\Users\Doug\.platformio\packages\framework-arduinoespressif32\tools\sdk
and I also added
“build_flags = -DCONFIG_FREERTOS_UNICORE=1”
in my platformio.ini file.
I can build and flash Espressif ESP32-Solo-1 board with ESP IDF 4.1 (stable version) and 4.2 (release branch version). I have an unsuccessful run with PIO using IDF Framework Setup. I have tried a few times.
I got the same error from the chip when running the basic Hello World firmware. The firmware did not run. Instead, the below message was continuously displayed.
Running on single core chip, but application is built with dual core support.␛[0m␛[0;31mE (239) cpu_start: Please enable CONFIG_FREERTOS_UNICORE option in menuconfig.␛[0m
I have attempted these following methods.
Method 1: #define CONFIG_FREERTOS_UNICORE 1 // ignored by PIO build
Method 2: build_flags = -DCONFIG_FREERTOS_UNICORE=1 // Build failed with errors.
PIO IDE Version 2.1 and ESP IDF 4.1. I would like to know how to get around it. Thank you.
