Please be noted that I’m very new to Platform.IO (~1 week), and had negligible experience in CMakeList.txt
I’ve tried to copy platformio.ini
, /board
& /zephyr
folder folder to the framework-zephyr-mcuboot
folder and tried to build there straightaway, after fixing some compilation error with the CMakeLists.txt
and possibly some other issues, I managed to build and flash it on my custom board, but it only output the Zephyr bootup string:
*** Booting Zephyr 20400 ***
and that’s it. I debugged and it turns out that the Zephyr OS was unable to locate an app (main.c
) file. I thought that it was because the CMakeLists.txt
in the framework-zephyr-mcuboot
package doesn’t have these lines:
FILE(GLOB app_sources ../src/*.c*)
target_sources(app PRIVATE ${app_sources})
And the fact that I was able to compile this thing gave me enough courage to scramble everything and start fresh from a Zephyr blinky example.
This time I copied and/or replaced:
/framework-zephyr-mcuboot/boot/zephyr/main.c
with /blinky/src/main.c
/framework-zephyr-mcuboot/boot/zephyr/prj.conf
with /blinky/zephyr/prj.conf
/framework-zephyr-mcuboot/boot/zephyr/dts.overlay
to /blinky/zephyr
folder
/framework-zephyr-mcuboot/boot/zephyr/Kconfig
to /blinky/zephyr
folder
as well as my custom board json definitions in blinky/board
folder and dts files in /blinky/zephyr/boards
folder.
I then edit the blinky/zephyr/CMakeLists.txt
by copying lines from the framework-zephyr-mcuboot
’s CMakeLists.txt
, and edited the MCUBOOT_FW
so that it points to the framework-mcuboot-zephyr
package like so:
get_filename_component(PIO_FW_DIR ${ZEPHYR_BASE} DIRECTORY)
# Path to the "framework-zephyr-mcuboot" platformio package
set(MCUBOOT_FW ${PIO_FW_DIR}/framework-zephyr-mcuboot)
And now I ended up with this error if full rebuild is performed:
<command-line>: fatal error: mcuboot-mbedtls-cfg.h: No such file or directory
* Looking for mcuboot-mbedtls-cfg.h dependency? Check our library registry!
* CLI > platformio lib search "header:mcuboot-mbedtls-cfg.h"
* Web > Compiling .pio\build\ivm22_f103re\arch__arm__core__aarch32__cortex_m\zephyr\arch\arch\arm\core\aarch32\cortex_m\irq_init.c.o
https://platformio.org/lib/search?query=header:mcuboot-mbedtls-cfg.hCompiling .pio\build\ivm22_f103re\..__-mbedtls\modules\framework-zephyr-mbedtls\library\x509_csr.c.o
Compiling .pio\build\ivm22_f103re\..__-mbedtls\modules\framework-zephyr-mbedtls\library\pkcs12.c.o
compilation terminated.
*** [.pio\build\ivm22_f103re\..__-mbedtls\modules\framework-zephyr-mbedtls\library\md4.c.o] Error 1
* Web > https://platformio.org/lib/search?query=header:mcuboot-mbedtls-cfg.h
*** [.pio\build\ivm22_f103re\..__-mbedtls\modules\framework-zephyr-mbedtls\library\x509_csr.c.o] Error 1
*** [.pio\build\ivm22_f103re\..__-mbedtls\modules\framework-zephyr-mbedtls\library\pkcs12.c.o] Error 1
Build again without clean ends up with this:
In file included from src\main.c:27:
C:\Users\yongc\.platformio\packages\framework-zephyr-mcuboot\boot\zephyr\include/target.h:42:2: error: #error "Target support is incomplete; cannot build mcuboot."
Compiling .pio\build\ivm22_f103re\kernel\zephyr\kernel\thread_abort.c.o
*** [.pio\build\ivm22_f103re\src\main.o] Error 1
The framework-zephyr-mcuboot/boot/zephyr/include/target.h
part that is giving me issue:
* Sanity check the target support.
#if (!defined(CONFIG_XTENSA) && !defined(DT_CHOSEN_ZEPHYR_FLASH_CONTROLLER_LABEL)) || \
(defined(CONFIG_XTENSA) && !defined(JEDEC_SPI_NOR_0_LABEL)) || \
!defined(FLASH_ALIGN) || \
!(FLASH_AREA_LABEL_EXISTS(image_0)) || \
!(FLASH_AREA_LABEL_EXISTS(image_1) || CONFIG_SINGLE_IMAGE_DFU) || \
(!defined(CONFIG_BOOT_SWAP_USING_MOVE) && !FLASH_AREA_LABEL_EXISTS(image_scratch) && !defined(CONFIG_SINGLE_IMAGE_DFU))
And I’m not sure what to do next.
This is my blinky’s CMakeLists.txt
file for anyone who is interested:
# Path to out-of-tree boards definitions
set (BOARD_ROOT "${CMAKE_CURRENT_SOURCE_DIR}")
cmake_minimum_required(VERSION 3.13.1)
#include($ENV{ZEPHYR_BASE}/cmake/app/boilerplate.cmake NO_POLICY_SCOPE)
# Add a common dts overlay necessary to ensure mcuboot is linked into,
# and fits inside, the boot partition. (If the user specified a
# DTC_OVERLAY_FILE on the CMake command line, we need to append onto
# the list).
if(DTC_OVERLAY_FILE)
set(DTC_OVERLAY_FILE
"${DTC_OVERLAY_FILE} ${CMAKE_CURRENT_LIST_DIR}/dts.overlay"
CACHE STRING "" FORCE
else()
set(DTC_OVERLAY_FILE ${CMAKE_CURRENT_LIST_DIR}/dts.overlay)
endif()
# Enable Zephyr runner options which request mass erase if so
# configured.
# Note that this also disables the default "leave" option when
# targeting STM32 DfuSe devices with dfu-util, making the chip stay in
# the bootloader after flashing.
# That's the right thing, because mcuboot has nothing to do since the
# chip was just erased. The next thing the user is going to want to do
# is flash the application. (Developers can reset DfuSE devices
# manually to test mcuboot behavior on an otherwise erased flash
# device.)
macro(app_set_runner_args)
if(CONFIG_ZEPHYR_TRY_MASS_ERASE)
board_runner_args(dfu-util "--dfuse-modifiers=force:mass-erase")
board_runner_args(pyocd "--flash-opt=-e=chip")
board_runner_args(nrfjprog "--erase")
endif()
endmacro()
# find_package(Zephyr) in order to load application boilerplate:
# http://docs.zephyrproject.org/application/application.html
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(zephyr_mcuboot)
MESSAGE("MCUBOOT_FW -> ${MCUBOOT_FW}")
# Path to "boot" subdirectory of repository root.
set(BOOT_DIR "${MCUBOOT_FW}/boot")
MESSAGE("BOOT_DIR -> ${BOOT_DIR}")
# Path to top-level repository root directory.
get_filename_component(MCUBOOT_DIR ${BOOT_DIR} DIRECTORY)
MESSAGE("MCUBOOT_DIR -> ${MCUBOOT_DIR}")
# Path to tinycrypt library source subdirectory of MCUBOOT_DIR.
set(TINYCRYPT_DIR "${MCUBOOT_DIR}/ext/tinycrypt/lib")
assert_exists(TINYCRYPT_DIR)
set(TINYCRYPT_SHA512_DIR "${MCUBOOT_DIR}/ext/tinycrypt-sha512/lib")
assert_exists(TINYCRYPT_SHA512_DIR)
# Path to crypto-fiat
set(FIAT_DIR "${MCUBOOT_DIR}/ext/fiat")
assert_exists(FIAT_DIR)
# Path to mbed-tls' asn1 parser library.
set(MBEDTLS_ASN1_DIR "${MCUBOOT_DIR}/ext/mbedtls-asn1")
assert_exists(MBEDTLS_ASN1_DIR)
set(NRF_DIR "${MCUBOOT_DIR}/ext/nrf")
if(CONFIG_BOOT_USE_NRF_CC310_BL)
set(NRFXLIB_DIR ${ZEPHYR_BASE}/../nrfxlib)
assert_exists(NRFXLIB_DIR)
# Don't include this if we are using west
add_subdirectory(${NRFXLIB_DIR} ${PROJECT_BINARY_DIR}/nrfxlib)
endif()
zephyr_library_include_directories(
${ZEPHYR_BASE}/drivers/flash
${BOOT_DIR}/zephyr/include
${BOOT_DIR}/zephyr/targets
${MCUBOOT_DIR}/ext/mbedtls-asn1/include
if(EXISTS targets/${BOARD}.h)
zephyr_library_compile_definitions(MCUBOOT_TARGET_CONFIG="${BOARD}.h")
endif()
# Zephyr port-specific sources.
zephyr_library_sources(
# main.c
${BOOT_DIR}/zephyr/flash_map_extended.c
${BOOT_DIR}/zephyr/os.c
${BOOT_DIR}/zephyr/keys.c
if(NOT DEFINED CONFIG_FLASH_PAGE_LAYOUT)
${BOOT_DIR}/zephyr/flash_map_legacy.c
endif()
# Generic bootutil sources and includes.
zephyr_library_include_directories(${BOOT_DIR}/bootutil/include)
${BOOT_DIR}/bootutil/src/image_validate.c
${BOOT_DIR}/bootutil/src/tlv.c
${BOOT_DIR}/bootutil/src/encrypted.c
${BOOT_DIR}/bootutil/src/image_rsa.c
${BOOT_DIR}/bootutil/src/image_ec256.c
${BOOT_DIR}/bootutil/src/image_ed25519.c
${BOOT_DIR}/bootutil/src/bootutil_misc.c
if(CONFIG_SINGLE_IMAGE_DFU)
${BOOT_DIR}/zephyr/single_loader.c
zephyr_library_include_directories(${BOOT_DIR}/bootutil/src)
else()
${BOOT_DIR}/bootutil/src/loader.c
${BOOT_DIR}/bootutil/src/swap_misc.c
${BOOT_DIR}/bootutil/src/swap_scratch.c
${BOOT_DIR}/bootutil/src/swap_move.c
${BOOT_DIR}/bootutil/src/caps.c
endif()
if(CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256 OR CONFIG_BOOT_ENCRYPT_EC256)
${MBEDTLS_ASN1_DIR}/include
# Additionally pull in just the ASN.1 parser from mbedTLS.
${MBEDTLS_ASN1_DIR}/src/asn1parse.c
${MBEDTLS_ASN1_DIR}/src/platform_util.c
if(CONFIG_BOOT_USE_TINYCRYPT)
# When using ECDSA signatures, pull in our copy of the tinycrypt library.
${TINYCRYPT_DIR}/include
${TINYCRYPT_DIR}/source/ecc.c
${TINYCRYPT_DIR}/source/ecc_dsa.c
${TINYCRYPT_DIR}/source/sha256.c
${TINYCRYPT_DIR}/source/utils.c
elseif(CONFIG_BOOT_USE_NRF_CC310_BL)
zephyr_library_sources(${NRF_DIR}/cc310_glue.c)
zephyr_library_include_directories(${NRF_DIR})
zephyr_link_libraries(nrfxlib_crypto)
endif()
# Since here we are not using Zephyr's mbedTLS but rather our own, we need
# to set MBEDTLS_CONFIG_FILE ourselves. When using Zephyr's copy, this
# variable is set by its Kconfig in the Zephyr codebase.
MBEDTLS_CONFIG_FILE="${CMAKE_CURRENT_LIST_DIR}/include/mcuboot-mbedtls-cfg.h"
elseif(CONFIG_BOOT_SIGNATURE_TYPE_NONE)
elseif(CONFIG_BOOT_SIGNATURE_TYPE_RSA)
# Use mbedTLS provided by Zephyr for RSA signatures. (Its config file
# is set using Kconfig.)
zephyr_include_directories(include)
elseif(CONFIG_BOOT_SIGNATURE_TYPE_ED25519 OR CONFIG_BOOT_ENCRYPT_X25519)
${TINYCRYPT_SHA512_DIR}/include
${TINYCRYPT_SHA512_DIR}/source/sha512.c
MBEDTLS_CONFIG_FILE="${BOOT_DIR}/zephyr/include/mcuboot-mbedtls-cfg.h"
else()
endif()
${FIAT_DIR}/include/
${FIAT_DIR}/src/curve25519.c
endif()
if(CONFIG_BOOT_ENCRYPT_EC256 OR CONFIG_BOOT_ENCRYPT_X25519)
${TINYCRYPT_DIR}/source/aes_encrypt.c
${TINYCRYPT_DIR}/source/aes_decrypt.c
${TINYCRYPT_DIR}/source/ctr_mode.c
${TINYCRYPT_DIR}/source/hmac.c
${TINYCRYPT_DIR}/source/ecc_dh.c
endif()
if(CONFIG_BOOT_ENCRYPT_EC256)
endif()
if(CONFIG_MCUBOOT_SERIAL)
zephyr_sources(${BOOT_DIR}/zephyr/serial_adapter.c)
zephyr_sources(${BOOT_DIR}/boot_serial/src/boot_serial.c)
zephyr_sources(${BOOT_DIR}/boot_serial/src/serial_recovery_cbor.c)
zephyr_sources(${BOOT_DIR}/boot_serial/src/cbor_decode.c)
zephyr_include_directories(${BOOT_DIR}/bootutil/include)
zephyr_include_directories(${BOOT_DIR}/boot_serial/include)
zephyr_include_directories_ifdef(
CONFIG_BOOT_ERASE_PROGRESSIVELY
endif()
# CONF_FILE points to the KConfig configuration files of the bootloader.
foreach (filepath ${CONF_FILE})
file(READ ${filepath} temp_text)
string(FIND "${temp_text}" ${CONFIG_BOOT_SIGNATURE_KEY_FILE} match)
if (${match} GREATER_EQUAL 0)
if (NOT DEFINED CONF_DIR)
get_filename_component(CONF_DIR ${filepath} DIRECTORY)
else()
message(FATAL_ERROR "Signature key file defined in multiple conf files")
endif()
endif()
endforeach()
if(NOT CONFIG_BOOT_SIGNATURE_KEY_FILE STREQUAL "")
if(IS_ABSOLUTE ${CONFIG_BOOT_SIGNATURE_KEY_FILE})
set(KEY_FILE ${CONFIG_BOOT_SIGNATURE_KEY_FILE})
elseif((DEFINED CONF_DIR) AND
(EXISTS ${CONF_DIR}/${CONFIG_BOOT_SIGNATURE_KEY_FILE}))
set(KEY_FILE ${CONF_DIR}/${CONFIG_BOOT_SIGNATURE_KEY_FILE})
else()
set(KEY_FILE ${MCUBOOT_DIR}/${CONFIG_BOOT_SIGNATURE_KEY_FILE})
endif()
message("MCUBoot bootloader key file: ${KEY_FILE}")
set(GENERATED_PUBKEY ${ZEPHYR_BINARY_DIR}/autogen-pubkey.c)
add_custom_command(
OUTPUT ${GENERATED_PUBKEY}
COMMAND
${PYTHON_EXECUTABLE}
${MCUBOOT_DIR}/scripts/imgtool.py
getpub
-k
${KEY_FILE}
> ${GENERATED_PUBKEY}
DEPENDS ${KEY_FILE}
zephyr_library_sources(${GENERATED_PUBKEY})
endif()
if(CONFIG_MCUBOOT_CLEANUP_ARM_CORE)
${BOOT_DIR}/zephyr/arm_cleanup.c
endif()
After all these now I feel like my first try is closer to the solution, but need to find a way to let the compiler ‘know’ that the app (main.c) is now in /zephyr
folder instead of the /src
folder. But my second approach seems like a ‘cleaner’ approach to me, without having to meddle with the platformio’s framework-zephyr-mcuboot
package, and the created mcuboot project (aka blinky) only requires a few files from the framework-zephyr-mcuboot
package
