I’ve tried to create a new simple project with the following setting, but it creates the issue that No such file or directory for Controller. map
[env:firebeetle32]
platform = https://github.com/tasmota/platform-espressif32/releases/download/v2.0.2idf/platform-espressif32-2.0.2.zip
board = firebeetle32
compiling process
Executing task in folder Motor Controller: C:\Users\Hamid\.platformio\penv\Scripts\platformio.exe run --environment firebeetle32 <
Processing firebeetle32 (platform: https://github.com/tasmota/platform-espressif32/releases/download/v2.0.2idf/platform-espressif32-2.0.2.zip; board: firebeetle32; framework: arduino)
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/firebeetle32.html
PLATFORM: Espressif 32 (2.0.2) > FireBeetle-ESP32
- framework-arduinoespressif32 2.0.2
- tool-esptoolpy 1.30200.211025 (3.2.0)
- tool-mklittlefs 1.203.210628 (2.3)
- toolchain-xtensa-esp32 8.4.0+2021r2
Found 30 compatible libraries
Linking .pio\build\firebeetle32\firmware.elf
xtensa-esp32-elf-g++: error: Controller.map: No such file or directory
*** [.pio\build\firebeetle32\firmware.elf] Error 1
========================================================================== [FAILED] Took 2.41 seconds ==========================================================================
also, I tried to clean and delete the build folders, but it was not successful while my other previous project with the same setting works fine
any tips really appreciate
