Hello
Building an project I get the following error. Looking into tte .pio/build/esp32-devkitc/ folder I can find a diybms_controller_firmware_espressif32_esp32-devkitc.map file but no .elf.
Linking .pio/build/esp32-devkitc/diybms_controller_firmware_espressif32_esp32-devkitc.elf
/Users/Sebastian/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: final link failed: bad value
*** [.pio/build/esp32-devkitc/diybms_controller_firmware_espressif32_esp32-devkitc.elf] Error 1
Does anybody has an idea what is the problem? I’m on OS X 10.15.7
Relevant part of platformio.ini
[env]
; 4MB FLASH DEVKITC
;platform = https://github.com/platformio/platform-espressif32.git#feature/arduino-upstream
monitor_port=COM4
monitor_filters = log2file, esp32_exception_decoder
board_build.flash_mode = dout
extra_scripts =
pre:buildscript_versioning.py
pre:prebuild_compress.py
pre:prebuild_generate_integrity_hash.py
pre:prebuild_generate_embedded_files.py
pre:bmp2array4bit.py
post:extract_bootloader.py
upload_speed=921600
upload_port=COM4
platform_packages =
toolchain-xtensa32 @ ~2.80400.0
platformio/tool-esptoolpy @ ~1.30100
framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git#2.0.3
(yes I know, I need to change the upload_port once compiling works)
Thanks in advance for your help
Sebastian
