kampi
#1
I use Visual Studio Code with PlatformIO 2.3.3
with esp-idf and Arduino:
- framework-arduinoespressif32 0.0.0+sha.3616c2e
- framework-espidf 3.40001.200521 (4.0.1)
- tool-cmake 3.16.4
- tool-idf 1.0.1
- tool-mconf 1.4060000.20190628 (406.0.0)
- tool-ninja 1.9.0
- toolchain-esp32ulp 1.22851.191205 (2.28.51)
- toolchain-xtensa32 3.80200.200512 (8.2.0)
I got the following error after the compilation of the firmware:
c:/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: cannot find -l.platformiopackagesframework-espidf@3.40001.200521componentsxtensaesp32libhal
*** [.pio\build\debug\bootloader.elf] Error 1
How can I resolve the issue?
And with what platformio.ini
is that?
kampi
#3
[platformio]
src_dir = src
[env]
# Use esp-idf version 3.40001.200521
platform = espressif32@1.12.4
framework = arduino, espidf
# 4 MB module version
board_upload.flash_size = 4MB
board_upload.maximum_size = 4194304
board_build.partitions = partitions_4MB.csv
upload_speed = 921600
upload_port = COM4
monitor_port = COM4
# 06/05/2021
# This version of the Arduino framework doesn´t support of ESP-IDF versions >4.0
platform_packages =
framework-arduinoespressif32@https://github.com/marcovannoord/arduino-esp32/tree/idf-release/v4.0
toolchain-xtensa32@3.80200.200512
[common]
# ESP32 specific (used by different libraries i. e. BLE)
-D ESP32
-D ARDUINO_ARCH_ESP32
-D ARDUINO_ESP32_DEV
# Only needed when PSRAM should be supported
#-D BOARD_HAS_PSRAM
# Only needed for ESP32 rev v1
#-mfix-esp32-psram-cache-issue
# Used by the esp32-camera driver
-D CONFIG_OV5640_SUPPORT
-D CONFIG_SCCB_HARDWARE_I2C
-D CONFIG_SCCB_HARDWARE_I2C_PORT1
# Used for ArduinoJSON
-D ARDUINOJSON_ENABLE_ARDUINO_STRING=1
lib_deps_builtin =
lib_deps_external =
espressif/esp32-camera@^1.0.0
bblanchon/ArduinoJson@^6.18.0
[env:debug]
build_type = debug
${common.build_flags}
-D DEBUG
-D ENABLE_DEBUG_PRINT
-D APP_VERSION_POST='"debug"'
${common.lib_deps_builtin}
${common.lib_deps_external}
What that I’m immediately getting
Cloning into ‘C:\Users\Max.platformio.cache\tmp\pkg-installing-8bi9y1af’…
fatal: repository ‘GitHub - marcovannoord/arduino-esp32 at idf-release/v4.0’ not found
Error: VCS: Could not process command [‘git’, ‘clone’, ‘–recursive’, ‘–depth’, ‘1’, ‘GitHub - marcovannoord/arduino-esp32 at idf-release/v4.0’, ‘C:\Users\Max\.platformio\.cache\tmp\pkg-installing-8bi9y1af’]
That can’t be correct. Had to replace it with
Further had to comment out the 4MB partition line because the file was not provided. Once I do that and take as code e.g. I get
Linking .pio\build\debug\firmware.elf
Retrieving maximum program size .pio\build\debug\firmware.elf
Building .pio\build\debug\firmware.bin
Checking size .pio\build\debug\firmware.elf
RAM: [ ] 4.0% (used 13016 bytes from 327680 bytes)
Flash: [== ] 16.7% (used 175069 bytes from 1048576 bytes)
esptool.py v2.6
================= [SUCCESS] Took 25.75 seconds =================
So, everything works for me. See GitHub - maxgerhardt/pio-espidf-arduino-repro: (Do not use, only for reproduction).
There seems to be another issue here as well.
If I create a completely empty new project with platformio.ini defined as:
framework = espidf
and a c file with an empty app_main() function, I get the same error as in the first post.
