Hi max…
I am sure that the creation of the queue is made first because I have other queues that I use in the same way but instead of passing a struct I am passing an array … I can change the timeout but why it should affect the system in this way? I can share yes
task.cpp
include "task_module.h"
#include <captive_portal.h>
#include <gpioa_module.h>
#include <modbus_mng.h>
#include <ethernet_module.h>
#include <machine.h>
#include <webserver_mng.h>
static const uint32_t STACK_SIZE_MQTT_TASK = 17000; /*optimal value to be defined*/
static const uint32_t STACK_SIZE_SERIAL_TASK = 4000; /*optimal value to be defined*/
static const uint32_t STACK_SIZE_ETHERNET_TASK = 1000; /*optimal value to be defined*/
static const uint32_t STACK_SIZE_GPIOA_TASK = 5000; /*optimal value to be defined*/
static const uint32_t STACK_SIZE_WEBSERVER_TASK = 20000; /*optimal value to be defined*/
static const uint16_t SERIAL_TASK_DELAY = 10; /*optimal value to be defined*/
static const uint16_t MQTT_TASK_DELAY = 100; /*optimal value to be defined*/
static const uint16_t ETHERNET_TASK_DELAY = 10; /*optimal value to be defined*/
static const uint16_t GPIOA_TASK_DELAY = 1000; /*optimal value to be defined*/
static const uint32_t WEBSERVER_DELAY = 500; /*500 is fine for running single webpage*/
UBaseType_t Mqtt_priority = 1; /*optimal value to be defined*/
UBaseType_t Serial_priority = 1; /*optimal value to be defined*/
UBaseType_t Ethernet_priority = 1; /*optimal value to be defined*/
UBaseType_t Gpioa_priority = 1; /*optimal value to be defined*/
UBaseType_t Webserver_priority = 1; /*optimal value to be defined*/
TaskHandle_t Mqtt_handle = NULL; /*for handling the task1 from outside the task*/
TaskHandle_t Serial_handle = NULL; /*for handling the task2 from outside the task*/
TaskHandle_t Ethernet_handle = NULL; /*for handling the task3 from outside the task*/
TaskHandle_t Gpioa_handle = NULL; /*for handling the task4 from outside the task*/
TaskHandle_t Webserver_handle = NULL; /*for handling the task4 from outside the task*/
QueueHandle_t alarms_queue_from_uart_to_wifi;
QueueHandle_t logs_queue_from_uart_to_wifi;
QueueHandle_t state_queue_from_uart_to_wifi;
QueueHandle_t physics_queue_from_uart_to_wifi;
QueueHandle_t report_queue_from_uart_to_wifi;
QueueHandle_t commands_queue_from_uart_to_wifi;
QueueHandle_t config_queue_from_uart_to_wifi;
QueueHandle_t program_upload_queue_from_uart_to_wifi;
UBaseType_t queue_lenght = 10; /*optimal value to be defined*/
UBaseType_t queue_lenght_commands = 1; /*optimal value to be defined*/
report_t report_struct;
* @brief Function to create the queue for exchanging data between Wifi and uart task
* @param None
* @retval None
void Create_queue_for_exchange_alarms_between_uart_and_wifi(void)
alarms_queue_from_uart_to_wifi = xQueueCreate(queue_lenght, NUM_REGISTERS_ALARMS * sizeof(uint16_t));
* @param None
* @retval None
void Create_queue_for_exchange_log_between_uart_and_wifi(void)
logs_queue_from_uart_to_wifi = xQueueCreate(queue_lenght, NUM_REGISTERS_LOG * sizeof(uint16_t));
* @param None
* @retval None
void Create_queue_for_exchange_state_between_uart_and_wifi(void)
state_queue_from_uart_to_wifi = xQueueCreate(queue_lenght, NUM_REGISTERS_MACHINE_STATE * sizeof(uint16_t));
* @param None
* @retval None
void Create_queue_for_exchange_physics_between_uart_and_wifi(void)
physics_queue_from_uart_to_wifi = xQueueCreate(queue_lenght, NUM_REGISTERS_PHYSICAL_VALUES * sizeof(uint16_t));
* @param None
* @retval None
void Create_queue_for_exchange_reports_between_uart_and_wifi(void)
report_queue_from_uart_to_wifi = xQueueCreate(1, sizeof(report_t));
* @param None
* @retval None
void Create_queue_for_exchange_commands_between_wifi_and_uart(void)
commands_queue_from_uart_to_wifi = xQueueCreate(queue_lenght_commands, NUM_REGISTERS_COMMANDS * sizeof(uint16_t));
* @param None
* @retval None
void Create_queue_for_exchange_config_between_wifi_and_uart(void)
config_queue_from_uart_to_wifi = xQueueCreate(queue_lenght, 1 * sizeof(uint16_t));
* @param None
* @retval None
void Create_queue_for_exchange_program_upload_between_wifi_and_uart(void)
program_upload_queue_from_uart_to_wifi = xQueueCreate(queue_lenght, 1 * sizeof(uint16_t));
* @brief Function to execute the creation of the first task
* @param None
* @retval None
void First_task_creation(void)
xTaskCreate(Mqtt_task, "Wifi", STACK_SIZE_MQTT_TASK, NULL, Mqtt_priority, &Mqtt_handle);
/*Block the task from running*/
vTaskSuspend(Mqtt_handle);
* @brief Function to execute the creation of the second task
* @param None
* @retval None
void Second_task_creation(void)
xTaskCreate(Communication_with_serial_task, "Uart", STACK_SIZE_SERIAL_TASK, NULL, Serial_priority, &Serial_handle);
vTaskSuspend(Serial_handle);
* @brief Function to execute the creation of the fourth task
* @param None
* @retval None
void Third_task_creation(void)
xTaskCreate(Communication_with_ethernet_task, "ETH", STACK_SIZE_ETHERNET_TASK, NULL, Ethernet_priority, &Ethernet_handle);
vTaskSuspend(Ethernet_handle);
* @brief Function to execute the creation of the fifth task
* @param None
* @retval None
void Fourth_task_creation(void)
xTaskCreate(Input_Output_analog_task, "GPIOA", STACK_SIZE_GPIOA_TASK, NULL, Gpioa_priority, &Gpioa_handle);
vTaskSuspend(Gpioa_handle);
* @brief Function to execute the creation of the sixth task
* @param None
* @retval None
void Seventh_task_creation(void)
xTaskCreate(Webserver_task, "WEBSERVER", STACK_SIZE_WEBSERVER_TASK, NULL, Webserver_priority, &Webserver_handle);
vTaskSuspend(Webserver_handle);
* @brief Function to execute the wifi task. Responsible for the captive portal and transmitting/receiving the data with Mqtt over wifi
* @param None
* @retval None
void Mqtt_task(void *parameters)
int result_captive_portal_config = 0;
/*start of the captive portal or wifi network connection*/
result_captive_portal_config = setup_captive_and_wifi();
if (result_captive_portal_config == 1)
setup_google_IOT_mqtt();
set_current_event(EVENT_OK_CREDENTIALS);
for (;;)
loop_google_IOT_mqtt();
vTaskDelay(MQTT_TASK_DELAY / portTICK_PERIOD_MS); /*tells at the scheduler to suspende the task for X ms*/
* @brief Function to execute the uart task. Responsible to communicate with external mcu with a specific frame protocol over uart
* @param None
* @retval None
void Communication_with_serial_task(void *parameters)
Init_modbus_registers();
for (;;)
Serial_task();
vTaskDelay(SERIAL_TASK_DELAY / portTICK_PERIOD_MS);
* @brief Function to execute the ethernet task
* @param None
* @retval None
void Communication_with_ethernet_task(void *parameters)
Ethernet_Init();
for (;;)
Ethernet_Task();
vTaskDelay(ETHERNET_TASK_DELAY / portTICK_PERIOD_MS);
* @brief Function to handle the Input Output and Analog signals directly connected with the board
* @param None
* @retval None
void Input_Output_analog_task(void *parameters)
gpioa_init();
for (;;)
vTaskDelay(GPIOA_TASK_DELAY / portTICK_PERIOD_MS);
* @brief Function to execute the webserver task (for OTA update and log)
* @param None
* @retval None
void Webserver_task(void *parameters)
uint8_t http_id_request_from_webserver = 0;
/*init of the ble task with properties*/
web_portal_init();
for (;;)
http_id_request_from_webserver = get_event_on_web_portal();
set_current_state_on_web_portal(get_current_state());
switch (http_id_request_from_webserver)
case HTTP_REQUEST_GO_TO_MAINTENANCE:
set_current_event(EVENT_HTTP_REQUEST_GO_MAINTENANCE);
break;
case HTTP_REQUEST_GO_TO_NORMAL:
set_current_event(EVENT_HTTP_REQUEST_GO_TO_NORMAL);
break;
case HTTP_REQUEST_GO_TO_INIT:
set_current_event(EVENT_HTTP_REQUEST_GO_TO_INIT);
break;
default:
// default statements
break;
reset_event_on_web_portal();
vTaskDelay(WEBSERVER_DELAY / portTICK_PERIOD_MS);
and the place where I have the crash and I try to receive the struct
#include "mqtt_mng.h"
#include <ArduinoJson.h>
#include <Json_payload_format.h>
#include "task_module.h"
uint32_t counter_ticks_wifi_task = 0;
static uint32_t refresh_time = 20;
static uint32_t refresh_esp32_status = 350; /*550 delay of wifi task more or less every 1 minute*/
bool first_config_received_flag = false;
static uint16_t commands_array[NUM_REGISTERS_COMMANDS] = {0};
EspStatus_t Status_Iot;
static uint8_t flag_first_time_connected_cloud = 0;
report_t report_struct_receive;
* @brief Function for initializing of the structure containing the status of the iot board
* @param *cmd pointer to the status structure
* @retval none
void init_iot_status_structure(EspStatus_t *status)
status->broker_connection = 0;
status->wifi_ethernet_selected = 0;
status->status_wifi_ethernet = 0;
status->command_to_apply = 0;
status->receipe_to_apply = 0;
status->update_to_apply = 0;
status->number_of_registers = 0;
* @brief Function for indicating that the connection with the broker is working
* @param *status pointer to the status structure
* @retval none
void set_broker_connection_is_active(EspStatus_t *status)
status->broker_connection = 1;
* @brief Function for indicating that the connection with the broker is not working
* @retval none
void set_broker_connection_is_not_active(EspStatus_t *status)
* @brief Function for indicating that the connection is made with the ethernet cable
* @retval none
void set_ethernet_connection_is_selected(EspStatus_t *status)
status->wifi_ethernet_selected = 1;
* @brief Function for indicating that the connection is made with the wifi
* @retval none
void set_wifi_connection_is_selected(EspStatus_t *status)
* @brief Function for setting the status of the wifi and the ethernet
* @param status_connection
* @retval none
void set_status_wifi_and_ethernet(EspStatus_t *status, bool status_connection)
status->status_wifi_ethernet = status_connection;
* @brief Function for indicating that there is a command to apply
* @retval none
void set_commands_to_apply(EspStatus_t *status)
status->command_to_apply = 1;
* @brief Function for indicating that there is no more a command to apply
* @retval none
void reset_commands_to_apply(EspStatus_t *status)
* @brief Function for indicating that there is a receipe to apply
* @retval none
void set_receipe_to_apply(EspStatus_t *status)
status->receipe_to_apply = 1;
* @brief Function for indicating that there is no more a receipe to apply
* @retval none
void reset_receipe_to_apply(EspStatus_t *status)
* @brief Function for indicating that there is an update to apply
* @retval none
void set_update_to_apply(EspStatus_t *status)
status->update_to_apply = 1;
* @brief Function for indicating that there is no more an update to apply
* @retval none
void reset_update_to_apply(EspStatus_t *status)
* @brief Function for indicating the number of registers to write
* @retval none
void set_registers_to_use(EspStatus_t *status, uint8_t number_of_registers_to_use)
status->number_of_registers = number_of_registers_to_use;
* @brief Function to reset the number of registers to write
* @retval none
void reset_registers_to_use(EspStatus_t *status)
* @brief Function to wait for new messages from the broker
* @param None
* @retval None
void setup_google_IOT_mqtt(void)
init_iot_status_structure(&Status_Iot);
/*relocate the following functions where they really need*/
set_broker_connection_is_active(&Status_Iot);
set_wifi_connection_is_selected(&Status_Iot);
set_status_wifi_and_ethernet(&Status_Iot, true);
set_commands_to_apply(&Status_Iot);
setupCloudIoT();
* @param None
* @retval None
void loop_google_IOT_mqtt(void)
static uint16_t array_logs_from_queue[NUM_REGISTERS_LOG] = {0};
static uint16_t array_alarms_from_queue[NUM_REGISTERS_ALARMS] = {0};
static uint16_t machine_status_value_from_queue[NUM_REGISTERS_MACHINE_STATE] = {0};
static uint16_t physical_value_from_queue[NUM_REGISTERS_PHYSICAL_VALUES] = {0};
// Serial.println("Transmitted");
mqtt->loop();
// the delay fixes some issues with WiFi stability
delay(10);
if (!mqttClient->connected())
connect();
* @brief The board begin to transmit only if a config message is received.
* Important note: it seems that a delay is necessary between two consecutive publish action,
* otherwhise the message is not transmited.
* To be evaluated and investigated.
if (first_config_received_flag == true)
++counter_ticks_wifi_task;
/*physical values topic transmitted only if modbus message is arrived*/
if (xQueueReceive(physics_queue_from_uart_to_wifi, &physical_value_from_queue, 0) == pdPASS)
physical_values_message(physical_value_from_queue);
Serial.println("Transmitted physics");
delay(10);
/*alarm topic transmitted only if modbus message is arrived*/
if (xQueueReceive(alarms_queue_from_uart_to_wifi, &array_alarms_from_queue, 0) == pdPASS)
alarms_message(array_alarms_from_queue);
Serial.println("Transmitted alarm");
delay(10);
/*log topic transmitted only if modbus message is arrived*/
if (xQueueReceive(logs_queue_from_uart_to_wifi, &array_logs_from_queue, 0) == pdPASS)
log_message(array_logs_from_queue);
Serial.println("Transmitted log");
delay(10);
/*machine status topic transmitted only if modbus message is arrived*/
if (xQueueReceive(state_queue_from_uart_to_wifi, &machine_status_value_from_queue, 0) == pdPASS)
machine_state_message(machine_status_value_from_queue);
Serial.println("Transmitted machine status");
delay(10);
/*report topic transmitted only if modbus message is arrived*/
if (xQueueReceive(report_queue_from_uart_to_wifi, (void *)&report_struct_receive, 0) == pdPASS)
send_report_message(report_struct_receive.machine_id, report_struct_receive.report_id, report_struct_receive.init_time,
report_struct_receive.end_time, report_struct_receive.duration);
Serial.println("Transmitted report topic");
delay(10);
/*iot status transmitted every refresh_esp32_status time*/
if (counter_ticks_wifi_task > refresh_esp32_status)
status_message();
Serial.println("Transmitted iot board status");
delay(10);
/*iot state transmitted only once*/
if (flag_first_time_connected_cloud == 0)
Serial.println("Transmitted iot board state first connection");
state_message();
flag_first_time_connected_cloud = 1;
delay(10);
* @brief Function for parsing the payload into a numeric value
* @param payload
* @retval id_command
uint16_t Parse_paylod_for_getting_machine_id(String payload)
String first_filter_string = "machineId";
String second_filter_string = "NumeroRicetta";
String id_command = payload.substring(payload.indexOf(first_filter_string), payload.indexOf(second_filter_string));
id_command = id_command.substring(id_command.indexOf(':') + 2, id_command.indexOf(',') - 1);
return id_command.toInt();
* @param payload
* @retval parameter_command
uint16_t Parse_paylod_for_getting_number_receipe(String payload)
String first_filter_string = "NumeroRicetta";
String second_filter_string = "ValorePressata";
* @param payload
uint16_t Parse_paylod_for_getting_valore_pressata(String payload)
String first_filter_string = "ValorePressata";
String second_filter_string = "ValoreTaglio";
* @param payload
uint16_t Parse_paylod_for_getting_valore_taglio(String payload)
String first_filter_string = "ValoreTaglio";
String second_filter_string = "ValoreGrammatura";
* @param payload
uint16_t Parse_paylod_for_getting_valore_grammatura(String payload)
String first_filter_string = "ValoreGrammatura";
String id_command = payload.substring(payload.indexOf(first_filter_string), payload.indexOf('}'));
* @brief Callback function from the messages coming from the server
* @param topic
* @param payload
* @retval none
void messageReceived(String &topic, String &payload)
Serial.println("incoming: " + topic + " - " + payload);
StaticJsonDocument<PROGRAMS_INCOMING_CAPACITY> doc;
DeserializationError err = deserializeJson(doc, payload);
if (err)
Serial.print(F("deserializeJson() failed with code "));
Serial.println(err.f_str());
if (topic.endsWith(COMMANDS_SUFFIX))
const char *command_name = doc["name"];
if ((strcmp(command_name, MACHINE_RECEIPE_COMMAND) == COMPARE_RESULT_OKAY))
/*parsing command values*/
commands_array[0] = Parse_paylod_for_getting_machine_id(payload);
commands_array[1] = Parse_paylod_for_getting_number_receipe(payload);
commands_array[2] = Parse_paylod_for_getting_valore_pressata(payload);
commands_array[3] = Parse_paylod_for_getting_valore_taglio(payload);
commands_array[4] = Parse_paylod_for_getting_valore_grammatura(payload);
/*Insert commands commands in the queue*/
if (xQueueSend(commands_queue_from_uart_to_wifi, &commands_array, 0) == pdPASS)
Serial.println("command element inserted in the queue!");
memset(commands_array, 0, NUM_REGISTERS_COMMANDS);
else
Serial.println("command queue is full!");
if ((strcmp(command_name, SET_OUTPUTS_CMD) == COMPARE_RESULT_OKAY))
Serial.println("entro!");
set_outputs(doc);
else if ((strcmp(command_name, PROGRAMS_DOWNLOAD_CMD) == COMPARE_RESULT_OKAY))
programs_download(doc);
* @brief Config topic set the interval between two consecutive state messages.
else if (topic.endsWith(CONFIG_SUFFIX))
if ((doc["statusIntervalSecs"]) != NULL)
refresh_time = static_cast<unsigned long>(doc["statusIntervalSecs"]);
Serial.println(refresh_time);
first_config_received_flag = true;
The crash appears in row 281
