Hi everyone,
I’d like to share libraries and a free tool I’ve been working on. They let you look inside running firmware: global variables show up as curves in a scope, and parameters can be changed while the program runs, without reflashing. Under the hood it’s XCP, the protocol automotive engineers use to measure and calibrate ECUs.
Libraries
x1xcp_serial: Arduino AVR (Nano, Uno, Mega), Raspberry Pi Pico (arduino-pico core) and STM32 (STM32duino), XCP over the USB serial port.Serial.print()keeps working, its text shows up in a console.x1xcp_esp32andx1xcp_esp8266: XCP on UDP over Wi-Fi.
PlatformIO setup
[env:pico]
platform = https://github.com/maxgerhardt/platform-raspberrypi.git
board = rpipico
board_build.core = earlephilhower
lib_deps = https://github.com/flmueller/x1xcp-serial.git
build_flags = -g ; debug info for the A2L
extra_scripts = post:scripts/x1_a2l.py ; writes the A2L after every build
The post-build script runs x1-elf2a2l, which reads addresses and types from the DWARF info of the ELF file. A short JSON list picks the variables and adds units, conversions, limits and events, so the A2L always matches the build.
In the sketch it’s a few lines:
#include <x1xcp_serial.h>
static const x1xcp::Event kEvents[] = {{"10ms", 10, false}};
x1xcp::Config xcp;
xcp.events = kEvents;
xcp.eventCount = 1;
x1xcp::begin(Serial, xcp);
x1xcp::poll();
// ... your code, then sample the 10 ms values:
x1xcp::trigger(0);
The tool
XCP-Ray runs on Windows and Linux and is free during the public beta: live scopes, value and bar displays, curve and map editors, recordings with MDF4/CSV export, and a Python API. It also talks to real ECUs over CAN, CAN FD, UDP and TCP.
- Download, manual and videos:
- https://xcp-ray.de
- https://youtu.be/vctjwOZx-YY
Feedback is very welcome, especially on boards or setups where something doesn’t work yet.
