I repeatedly experienced PIO building another project when I clicked on the Build or Upload icons in VSCode. Most of the time this were projects where I had opened or copied single source files while working on another (main) project. But occasionally the project built was even one I had never touched at all.
Is there a way to tell PIO to focus on a single project only?
The new extension version has a different project selection mechanism with an explicit selector at the bottom taskbar – if you update the extension to 2.3.0 you will see it. Otherwise it was noted somewhere else that some VSCode API had broken that was used to previously select it.
