I’m using Vscode and my code is not working ;-; here my error:
CONFIGURATION: //docs.platformio.org/page/boards/espressif32/esp32doit-devkit-v1.html
PLATFORM: Espressif 32 (6.5.0) > DOIT ESP32 DEVKIT V1
- framework-arduinoespressif32 @ 3.20014.231204 (2.0.14)
- tool-mkfatfs @ 2.0.1
LDF: Library Dependency Finder -> bit.ly/configure-pio-ldf
Found 34 compatible libraries
Compiling .pio\build\firebeetle32\src\main.cpp.o
Retrieving maximum program size .pio\build\firebeetle32\firmware.elf
Checking size .pio\build\firebeetle32\firmware.elf
RAM: [= ] 6.5% (used 21408 bytes from 327680 bytes)
Flash: [== ] 20.3% (used 265913 bytes from 1310720 bytes)
AVAILABLE: cmsis-dap, esp-bridge, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Using manually specified: COM3
Uploading .pio\build\firebeetle32\firmware.bin
esptool.py v4.5.1
Serial port COM3
Connecting......................................
A fatal error occurred: Failed to connect to ESP32: Wrong boot mode detected (0x1b)! The chip needs to be in download mode.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
*** [upload] Error 2
pls help me
