Greetings,
I cannot figure out how to get this to resolve, i have included wire.h in the ini file. In reading through the code it looks like AVR_AVR128DB48 needs to be defined for WIRE1 to be defined.
How can i define AVR_AVR128DB48 in a macro and have it accessible by the underlying library?
.pio\libdeps\AVR128DB48\AVR-IoT MCP9808\src\mcp9808.cpp:5:14: error: ‘Wire1’ was not declared in this scope
Any help and or guidance would be appreciated as this is making me crazy-:).
-m
This error is reproducable for me with
[env:AVR128DB48]
platform = atmelmegaavr
board = AVR128DB48
https://github.com/microchip-pic-avr-solutions/mcp9808_arduino_driver.git
and src/main.cpp with the content from read_temp.ino. So let’s figure this one out…
Well that was easy. As can be seen in
there needs to be a macro activated to enable the Wire1 creation. Per docs that can be added using
build_flags = -DTWI_USING_WIRE1
in the platformio.ini.
Adding that the the above file makes the firmware compile without any problems.
Linking .pio\build\AVR128DB48\firmware.elf
Checking size .pio\build\AVR128DB48\firmware.elf
RAM: [= ] 5.9% (used 974 bytes from 16384 bytes)
Flash: [ ] 5.0% (used 6534 bytes from 131072 bytes)
Building .pio\build\AVR128DB48\firmware.hex
==================== [SUCCESS] Took 2.87 seconds ====================
Max, Thank you, that did it!
-m
