Here is my code:
The teensy samples an AS5600 encoder (i2c) position periodically,
recorded via serial to PC
connections:
as5600 -- teensy 3.2
5V ------- 3V3
3V ------- 3V3
GND ------ GND
SCL ------ 19/A5/SCL0 (4.7k pullup)
SDA ------ 18/A5/SDA0 (4.7k pullup)
DIR ------ (4.7k pullup)
#include "AS5600.h"
#include "Wire.h"
AS5600 as5600; // use default Wire
//pins
const int buttonPin = 3;
//button pin pullup
pinMode(buttonPin, INPUT_PULLUP);
//initialize encoder
// Wire.begin(I2C_SDA, I2C_SCL);
Wire.begin(18, 19);
as5600.begin();
//start serial
Serial.println("Waiting for user to push button");
//wait for button push
while (digitalRead(buttonPin)) {}
Serial.println(as5600.rawAngle());
Here is my platformio.ini
[env:teensy31]
platform = teensy
board = teensy31
robtillaart/AS5600@^0.4.0
Wire
lib_archive = false
monitor_port = COM3
I get the following error:
Compiling .pio\build\teensy31\FrameworkArduino\EventResponder.cpp.o
src\main.cpp: In function 'void setup()':
Compiling .pio\build\teensy31\FrameworkArduino\HardwareSerial.cpp.o
src\main.cpp:35:13: error: no matching function for call to 'TwoWire::begin(
Compiling .pio\build\teensy31\FrameworkArduino\HardwareSerial1.cpp.o
35 | Wire.begin(18, 19);
In file included from C:\Users\x\.platformio\packages\framework-arduinotee
from .pio\libdeps\teensy31\AS5600/AS5600.h:12,
from src\main.cpp:18:
C:\Users\x\.platformio\packages\framework-arduinoteensy\libraries\Wire/Wir
104 | void begin();
105 | void begin(uint8_t address);
106 | void begin(int address) {
*** [.pio\build\teensy31\src\main.cpp.o] Error 1
