It appears the Wio Lite Risc-V board hasn’t been fully implemented in PlatformIO. The pins.arduino.h and pins.arduino.c files have not been added to the Arduino/GD32 Framework “framework-arduino-gd32v\variants\gd32vf103 directory”. Therefore, the Arduino Blink Demo program won’t compile.
If you have a working Arduino pin map then could you submit this as a pull request to Maixduino/variants at master · sipeed/Maixduino · GitHub? If not at least the issue should be opened at that repository so it reaches the right people.
Thanks Max,
I’ll consider submitting a pull when I eventually get this running and I can test some things
Dan
