Windows on arm64 problem installing xtensa toolchain
I’m using a Surface Pro X running Windows on Arm64 (20H2) and running the 32 bit version of VS Code.
I’m trying to compile a ESP8266 project, but the build output just outputs the following message:
Executing task: C:\Users\USERNAME\.platformio\penv\Scripts\platformio.exe run --environment ota <
Processing ota (platform: espressif8266; board: nodemcuv2; framework: arduino)
Tool Manager: Installing platformio/toolchain-xtensa @ ~2.100300.0
Error: Could not find the package with ‘platformio/toolchain-xtensa @ ~2.100300.0’ requirements for your system ‘windows_arm64’
The terminal process “C:\Users\USERNAME\.platformio\penv\Scripts\platformio.exe ‘run’, ‘–environment’, ‘ota’” terminated with exit code: 1.
pio system info gives the following output:
PlatformIO Core 5.2.4
Python 3.9.8-final.0
System Type windows_arm64
Platform Windows-10
File System Encoding utf-8
Locale Encoding cp1252
PlatformIO Core Directory C:\Users\cnienhaus.platformio
PlatformIO Core Executable platformio.exe
Python Executable C:\Users\cnienhaus.platformio\penv\Scripts\python.exe
Global Libraries 0
Development Platforms 1
Tools & Toolchains 1
It seems like platformio cannot find the right toolchain for windows_arm64.
Weird thing is that everything worked perfectly fine yesterday.
Does anyone know how to solve this issue?
Is it maybe possible to force platformio to use the windows_x86 platform through emulation?
Thanks for any help
Correct, no such package is uploaded, as listed in PlatformIO Registry.
I also don’t know of any easily downloadable xtensa-gcc package for native Windows ARM64. Distributors like these only have x86 and x86_64 Windows.
According to Introducing x64 emulation in preview for Windows 10 on ARM PCs to the Windows Insider Program | Windows Insider Blog some sort of emulation is available (?). Can you download + extract the x64 version and confirm whether or not xtensa-lx106-elf-gcc.exe --version runs in a shell without hassle?
Sadly, x64 emulation for Windows on Arm is not available (as far as i know, it requires installing a insider build or windows 11, both of which are not a option for me)
Running the x64 version from the given link gives me the following error, indicating that it’s not compatible with my system:
ResourceUnavailable: Program ‘xtensa-lx106-elf-gcc.exe’ failed to run: An error occurred trying to start process ‘C:\Users\USERNAME\Downloads\toolchain-xtensa-windows_amd64-2.100300.210717\bin\xtensa-lx106-elf-gcc.exe’ with working directory ‘C:\Users\USERNAME\Downloads\toolchain-xtensa-windows_amd64-2.100300.210717\bin’. The specified executable is not a valid application for this OS platform.
However, using the x86 version, it seems to work just fine:
xtensa-lx106-elf-gcc.exe (GCC) 10.3.0
Copyright (C) 2020 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
That is quite baffling, so there has to be an emulation somehow, for x86, but not x64? Hm.
@ivankravets can you enable windows_arm64 compatibility in all windows_x86 PlatformIO packages to solve this problem?
Could I ask you to re-test the full building workflow before we enable windows_arm64 for all windows x86 packages?
  1. Unpack this package to %HOME_PATH%/.platformio/packages/toolchain-xtensa
  2. Open toolchain-xtensa/package.json manifest in VSCode, replace:
  "system": [
    "windows_x86"
with
  "system": [
    "windows_x86",
    "windows_arm64"
  1. Try building any ESP8266-based project.
Does it work?
Only unpacking the package and updating package.json like you suggested does not work (at least not by itself):
The terminal process “C:\Users\USERNAME.platformio\penv\Scripts\platformio.exe ‘run’, ‘–environment’, ‘ota’” terminated with exit code: 1.
However, i noticed that on another machine, each package had a .piopm file alongside the package.json. Copying that over from the other machine to mine makes platformio recognise the package just fine, but now it clomplains that ‘tool-esptool’ is missing:
Tool Manager: Installing platformio/framework-arduinoespressif8266 @ ~3.30002.0
Tool Manager: framework-arduinoespressif8266 @ 3.30002.0 has been installed!
Tool Manager: Installing platformio/tool-esptool @ <2
Error: Could not find the package with ‘platformio/tool-esptool @ <2’ requirements for your system ‘windows_arm64’
After repeating the same steps (download the package, copy package.json and .piopm over, and modify package.json to include ‘windows_arm64’) for ‘tool-esptool’, ‘mklittlefs’ and ‘mkspiffs’
, i’m actually able to build the project, and even upload it OTA:
Tool Manager: Installing platformio/tool-esptoolpy @ ~1.30000.0
Tool Manager: tool-esptoolpy @ 1.30000.201119 has been installed!
Tool Manager: Installing platformio/tool-scons @ ~4.40300.0
Tool Manager: tool-scons @ 4.40300.1 has been installed!
CONFIGURATION: https:// docs.platformio. org/page/boards/espressif8266/nodemcuv2.html
PLATFORM: Espressif 8266 (3.2.0) > NodeMCU 1.0 (ESP-12E Module)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
– framework-arduinoespressif8266 3.30002.0 (3.0.2)
– tool-esptool 1.413.0 (4.13)
– tool-esptoolpy 1.30000.201119 (3.0.0)
– toolchain-xtensa 2.100300.210717 (10.3.0)
LDF: Library Dependency Finder → https:// bit. ly/configure-pio-ldf
Library Manager: Installing z3t0/IRremote @ ^3.5.1
Library Manager: IRremote @ 3.5.1 has been installed!
Found 36 compatible libraries
Scanning dependencies…
|-- IRremote 3.5.1
|-- ESP8266WebServer 1.0
| |-- ESP8266WiFi 1.0
|-- ESP8266WiFi 1.0
|-- LittleFS 0.1.0
|-- ArduinoOTA 1.0
| |-- ESP8266WiFi 1.0
| |-- ESP8266mDNS 1.2
| | |-- ESP8266WiFi 1.0
|-- ESP8266mDNS 1.2
Compiling .pio\build\ota\src\main.cpp.o
Archiving .pio\build\ota\libFrameworkArduino.a
Linking .pio\build\ota\firmware.elf
Retrieving maximum program size .pio\build\ota\firmware.elf
Checking size .pio\build\ota\firmware.elf
RAM: [==== ] 37.5% (used 30760 bytes from 81920 bytes)
Flash: [=== ] 34.8% (used 363936 bytes from 1044464 bytes)
Configuring upload protocol…
AVAILABLE: espota, esptool
CURRENT: upload_protocol = espota
Uploading .pio\build\ota\firmware.bin
13:57:46 [DEBUG]: Options: {‘esp_ip’: ‘***’, ‘host_ip’: ‘0.0.0.0’, ‘esp_port’: 8266, ‘host_port’: 11671, ‘auth’: ‘’, ‘image’: ‘.pio\build\ota\firmware.bin’, ‘spiffs’: False, ‘debug’: True, ‘progress’: True}
13:57:46 [INFO]: Starting on 0.0.0.0:11671
13:57:46 [INFO]: Upload size: 368096
13:57:46 [INFO]: Sending invitation to: ***
13:57:46 [INFO]: Waiting for device…
Uploading: [============================================================] 100% Done…
13:57:52 [INFO]: Waiting for result…
13:57:53 [INFO]: Result: OK
So it seems like everything is working perfectly fine using the tools for windows_x86 on arm64.
Is there a setting that can be changed so all packages that don’t have native arm64 builds run under x64 emulation?
x64 emulation has been available for Windows 11 on the Pro X since November 2021.
Having to manually modify the platform.json and copy files from another host for every package used in a project is a hassle, especially when it doesn’t work.
tbh, thinking about this a bit, it would make sense to use x86 as a fallback for ALL Windows platforms, since every Windows version should support it either natively or via emulation.
basically check if the target can run x64, and if it can’t fallback to x86
Hi @shadow578,
I’m currently stuck in the same Issue as you with a Surface Pro 11th on W11 ARM, but I don’t know how I can find the other .piopm file, do you know how I can do?
Thanks for the tips
Hi @melvinlebailly22 ,
the .piopm files are generated by the platformio package manager, the component that checks & installs the packages for the platformio cli / ide.
to get platformio to work on Win ARM, you’ll have to first install the packages on a NON-ARM windows computer, then copy the packages from C:/Users/%USERNAME%/.platformio/packages/ over to the Win ARM machine.
This is what ended up working for me back then, tho i’m not quite sure about the details.
TBH, i’m quite astonished that this issue still persists over 2 years after beign known…
EDIT: created a PR that should allow this issue to be worked around @ allow manual override of system type by shadow578 · Pull Request #4952 · platformio/platformio-core · GitHub. literally took 5 minutes…
Okay, thank you very much,
Unfortunately, I didn’t have non-ARM PC with me for the moment, but I will find a solution.
And maybe your PR will be accepted soon, in that case that will be perfect!
see below for the .piopm files for toolchain-gccarmnoneeabi and toolchain-xtensa32. maybe they’ll help?
{"type": "tool", "name": "toolchain-gccarmnoneeabi", "version": "1.120301.0", "spec": {"owner": "platformio", "id": 8207, "name": "toolchain-gccarmnoneeabi", "requirements": null, "uri": null}}
{"type": "tool", "name": "toolchain-xtensa32", "version": "2.50200.97", "spec": {"owner": "platformio", "id": 8222, "name": "toolchain-xtensa32", "requirements": null, "uri": null}}
Hi @shadow578,
Thank you very much for all your help, I succeed to compile everything,
Last question, the PR that you create, is there a way I add this modification of the Util.py fill on my local version of PlatformIO?
So, I will not need any more to use another Computer for every new package.
If it’s possible, do you know where I can find the file Util.py ?
Thanks
set env variable to windows_arm64 and you’re done
No, you’ll want to set it windows_amd64, so that the ARM system acts like it’s an AMD64 system.
As discussed in
All Windows packages have been repacked with a support for ARM64. Please re-test.
