I had PlatformIO working on my windows 10 machine in VSCode some time ago. I’ve since worked on a number of other Python and Java projects.
Today I tried to open an old Platform IO project and the PlatformIO extension did not load. I opened the project by opening a folder within VSCode and it looked fine, but I did not get the PlatformIO toolbar appearing at the bottom of the screen and when I pressed ctrl + alt + t, I get a message in the toolbar saying Activating Extention which then disappears without the task list appearing.
I then uninstalled the PlatformIO extension and reinstalled it, exactly the same behaviour.
I then remove VSCode completely, by running the uninstaller, and deleting the folders C:\Users\.vscode and C:\Users<myuser>\AppData\Roaming\Code. From my understanding that should have completely remove VSCode and all the extensions.
I then reinstalled VSCode and the PlatfomIO extension, the extension downloaded the C/C++ extensions, but again the behaviour remains the same.
I then built a new Windows 10 VM and performed the same operation, only this time I noticed it informed me it was installing platformIO Core, which my previous reinstall attempt did not. So I repeated the reinstall on my dev machine and again it does not appear to download platformIO Core.
I think I’m not installing everything that needs to be removed, but any guidance will be greatly appreciated
Remove the PlatformIO extension from VSCode, then remove the folder C:\Users\<user>\.platformio completely (removes the core). Then restart VSCode and install the PlatformIO extension again. Does it now install the core?
