I’ve setup a small test project utilizing wifi of my ESP32 (DoIt DevKit).
The password starts with a $
and this seems to cause trouble.
When hardcoding the password or defining a var like this, it is working:
const char *password = "$test&Password$";
// OR
#define WIFI_PW "$tes&tPassword$"
#pragma message "Wifi Value " WIFI_PW
When defining the password in the platformio.ini
as build_flags
it becomes weird.
'-D WIFI_SSID="ssid"'
'-D WIFI_PW="$test&Password$"'
outputs note: #pragma message: Wifi Value
'-D WIFI_PW="\$test&Password$"'
outputs
Generating LD script .pio/build/serial/memory.ld
sh: -c: line 0: unexpected EOF while looking for matching `"'
sh: -c: line 1: syntax error: unexpected end of file
'-D WIFI_PW="\\$test&Password$"'
outputs
<command-line>: warning: unknown escape sequence: '\&'
src/main.cpp:11:31: note: in expansion of macro 'WIFI_PW'
<command-line>: note: #pragma message: Wifi Value &Password$
src/main.cpp:14:24: note: in expansion of macro 'WIFI_PW'
const char *password = WIFI_PW;
Maybe this is the wrong approach of passing wifi credentials to my firmware.
How could I overcome this problem?
