I’ve seen other issues with the same problem , but I cannot find a satisfactory solution for this …
As our project grows and grows, I want to disable the LDF and specify each used library explicitly in the platformio.ini. Searching for dependencies is taking way too long, and is not changing that often.
It all works fine when specifying build-in libraries like SPIFFS, Preferences, FS etc in the lib_deps … but the only one not working is WiFi
So can anybody tell me why the platformio.ini as copied below, still fails to compile with a fatal error: WiFi.h: No such file or directory when being included in on of the .cpp files with #include "WiFi.h"
If I specify the include with a full absolute path like #include "c:\Users\Bas\.platformio\packages\framework-arduinoespressif32\libraries\WiFi\src\WiFi.h" it is working btw, without errors
[env]
platform = espressif32@^5.0.0
lib_ldf_mode = off
bblanchon/ArduinoJson@^6.19.0
EEPROM
ESP32 BLE Arduino
FS
https://github.com/dmkishi/Dusk2Dawn.git
https://github.com/I-Connect/Esp32Logging
https://github.com/I-Connect/Sense_Timer
https://github.com/I-Connect/SenseSupport
https://github.com/I-Connect/StreamDebugger
https://github.com/sudar/MemoryFree
Preferences
PubSubClient
SPIFFS
WiFi
Wire
The dependency is found during build btw:
|-- ArduinoJson @ 6.19.4
|-- EEPROM @ 2.0.0
|-- ESP32 BLE Arduino @ 2.0.0
|-- FS @ 2.0.0
|-- Dusk2Dawn @ 1.0.1+sha.2e12244
|-- ESP32 logger @ 1.0.2+sha.2e1d2b2
|-- Sense_Timer @ 0.0.0+sha.fe2adaa
|-- SenseSupport @ 0.0.0+20210527222300.sha.0f233c2
|-- StreamDebugger @ 1.0.3+sha.503d574
|-- MemoryFree @ 0.0.0+20220727233332.sha.b1db159
|-- Preferences @ 2.0.0
|-- PubSubClient @ 2.8.0
|-- SPIFFS @ 2.0.0
|-- WiFi @ 2.0.0
|-- Wire @ 2.0.0
