platformio.ini:
[env:pico]
platform = raspberrypi
board = pico
-Wno-ignored-qualifiers
-Wno-nonnull
My main.cpp has the following:
#include <Adafruit_TinyUSB.h>
The project compiles on Mac with no problem but fails on Windows (log below). Any suggestions? This is the standard Arduino core so I presume it’s not subject to the Windows long line issue.
The full project is here: https://github.com/zapta/GreenPAKs/tree/main/pico_i2c/platformio
My goal is to have USB/Serial that doesn’t require manual driver installation on Max/Windows/Linux and works well with the Arduino uploader (on platformio and Arduino IDE), and I prefer not to use the earlephilhower core.
Processing pico (platform: raspberrypi; board: pico; framework: arduino; build_flags: -Wno-ignored-qualifiers, -Wno-nonnull)
--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------CONFIGURATION: https://docs.platformio.org/page/boards/raspberrypi/pico.html
PLATFORM: Raspberry Pi RP2040 (1.10.0) > Raspberry Pi Pico
HARDWARE: RP2040 133MHz, 264KB RAM, 2MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, jlink, raspberrypi-swd)
- framework-arduino-mbed @ 4.0.10
- tool-rp2040tools @ 1.0.2
- toolchain-gccarmnoneeabi @ 1.90201.191206 (9.2.1)
Found 42 compatible libraries
|-- Wire (License: Unknown, Path: C:\Users\user\.platformio\packages\framework-arduino-mbed\libraries\Wire)
arm-none-eabi-g++ -o .pio\build\pico\src\main.cpp.o -c -Wvla -fno-rtti -std=gnu++14 -Wno-ignored-qualifiers -Wno-nonnull -DMBED_TRAP_ERRORS_ENABLED=1 -Os -Wall -Wextra -Wno-missing-field-initializers -Wno-unused-parameter -c -fdata-sections -ffunction-sections -fmessage-length=0 -fno-exceptions -fomit-frame-pointer -funsigned-char -mcpu=cortex-m0plus -mthumb -iprefixC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino @C:\Users\user\.platformio\packages\framework-arduino-mbed\variants\RASPBERRY_PI_PICO\includes.txt -nostdlib -DPLATFORMIO=60111 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_RP2040 -DARM_MATH_CM0PLUS -D__CMSIS_RTOS -DCOMPONENT_FLASHIAP=1 -D__CORTEX_M0PLUS -DDEVICE_ANALOGIN=1 -DDEVICE_FLASH=1 -DDEVICE_I2C=1 -DDEVICE_I2CSLAVE=1 -DDEVICE_INTERRUPTIN=1 -DDEVICE_PORT_IN=1 -DDEVICE_PORT_OUT=1 -DDEVICE_PWMOUT=1 -DDEVICE_RESET_REASON=1 -DDEVICE_RTC=1 -DDEVICE_SERIAL=1 -DDEVICE_SERIAL_FC=1 -DDEVICE_SPI=1 -DDEVICE_USBDEVICE=1 -DDEVICE_USTICKER=1 -DDEVICE_WATCHDOG=1 -D__MBED__=1 -DMBED_BUILD_TIMESTAMP=1700585028.014541 -D__MBED_CMSIS_RTOS_CM -DMBED_MPU_CUSTOM -DMBEDTLS_ENTROPY_NV_SEED -DPICO_NO_BINARY_INFO=1 -DPICO_ON_DEVICE=1 -DPICO_RP2040_USB_DEVICE_ENUMERATION_FIX=1 -DPICO_TIME_DEFAULT_ALARM_POOL_DISABLED -DPICO_UART_ENABLE_CRLF_SUPPORT=0 -DTARGET_CORTEX -DTARGET_CORTEX_M -DTARGET_LIKE_CORTEX_M0 -DTARGET_LIKE_MBED -DTARGET_M0P -DTARGET_memmap_default -DTARGET_NAME=RASPBERRY_PI_PICO -DTARGET_RASPBERRYPI -DTARGET_RASPBERRY_PI_PICO -DTARGET_RELEASE -DTARGET_RP2040 -DTOOLCHAIN_GCC -DTOOLCHAIN_GCC_ARM -DMBED_NO_GLOBAL_USING_DIRECTIVE=1 -DCORE_MAJOR=4 -DCORE_MINOR=0 -DCORE_PATCH=10 -DUSE_ARDUINO_PINOUT -DARDUINO=10810 -DARDUINO_ARCH_MBED -Isrc -IC:\Users\user\.platformio\packages\framework-arduino-mbed\libraries\Wire -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino\api\deprecated -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino\api\deprecated-avr-comp -IC:\Users\user\.platformio\packages\framework-arduino-mbed\variants\RASPBERRY_PI_PICO src\main.cpp
arm-none-eabi-g++ -E -P -x c -DMBED_BOOT_STACK_SIZE=1024 -DXIP_ENABLE=1 C:\Users\user\.platformio\packages\framework-arduino-mbed\variants\RASPBERRY_PI_PICO\linker_script.ld -o .pio\build\pico\cpp.linker_script.ld
arm-none-eabi-g++ -o .pio\build\pico\libd06\Wire\Wire.cpp.o -c -Wvla -fno-rtti -std=gnu++14 -Wno-ignored-qualifiers -Wno-nonnull -DMBED_TRAP_ERRORS_ENABLED=1 -Os -Wall -Wextra -Wno-missing-field-initializers -Wno-unused-parameter -c -fdata-sections -ffunction-sections -fmessage-length=0 -fno-exceptions -fomit-frame-pointer -funsigned-char -mcpu=cortex-m0plus -mthumb -iprefixC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino @C:\Users\user\.platformio\packages\framework-arduino-mbed\variants\RASPBERRY_PI_PICO\includes.txt -nostdlib -DPLATFORMIO=60111 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_RP2040 -DARM_MATH_CM0PLUS -D__CMSIS_RTOS -DCOMPONENT_FLASHIAP=1 -D__CORTEX_M0PLUS -DDEVICE_ANALOGIN=1 -DDEVICE_FLASH=1 -DDEVICE_I2C=1 -DDEVICE_I2CSLAVE=1 -DDEVICE_INTERRUPTIN=1 -DDEVICE_PORT_IN=1 -DDEVICE_PORT_OUT=1 -DDEVICE_PWMOUT=1 -DDEVICE_RESET_REASON=1 -DDEVICE_RTC=1 -DDEVICE_SERIAL=1 -DDEVICE_SERIAL_FC=1 -DDEVICE_SPI=1 -DDEVICE_USBDEVICE=1 -DDEVICE_USTICKER=1 -DDEVICE_WATCHDOG=1 -D__MBED__=1 -DMBED_BUILD_TIMESTAMP=1700585028.014541 -D__MBED_CMSIS_RTOS_CM -DMBED_MPU_CUSTOM -DMBEDTLS_ENTROPY_NV_SEED -DPICO_NO_BINARY_INFO=1 -DPICO_ON_DEVICE=1 -DPICO_RP2040_USB_DEVICE_ENUMERATION_FIX=1 -DPICO_TIME_DEFAULT_ALARM_POOL_DISABLED -DPICO_UART_ENABLE_CRLF_SUPPORT=0 -DTARGET_CORTEX -DTARGET_CORTEX_M -DTARGET_LIKE_CORTEX_M0 -DTARGET_LIKE_MBED -DTARGET_M0P -DTARGET_memmap_default -DTARGET_NAME=RASPBERRY_PI_PICO -DTARGET_RASPBERRYPI
-DTARGET_RASPBERRY_PI_PICO -DTARGET_RELEASE -DTARGET_RP2040 -DTOOLCHAIN_GCC -DTOOLCHAIN_GCC_ARM -DMBED_NO_GLOBAL_USING_DIRECTIVE=1 -DCORE_MAJOR=4 -DCORE_MINOR=0 -DCORE_PATCH=10 -DUSE_ARDUINO_PINOUT -DARDUINO=10810 -DARDUINO_ARCH_MBED -IC:\Users\user\.platformio\packages\framework-arduino-mbed\libraries\Wire -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino\api\deprecated -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino\api\deprecated-avr-comp -IC:\Users\user\.platformio\packages\framework-arduino-mbed\variants\RASPBERRY_PI_PICO C:\Users\user\.platformio\packages\framework-arduino-mbed\libraries\Wire\Wire.cpp
arm-none-eabi-g++ -o .pio\build\pico\FrameworkArduinoVariant\double_tap_usb_boot.cpp.o -c -Wvla -fno-rtti -std=gnu++14 -Wno-ignored-qualifiers -Wno-nonnull -DMBED_TRAP_ERRORS_ENABLED=1 -Os -Wall -Wextra -Wno-missing-field-initializers -Wno-unused-parameter -c -fdata-sections -ffunction-sections -fmessage-length=0 -fno-exceptions -fomit-frame-pointer -funsigned-char -mcpu=cortex-m0plus -mthumb -iprefixC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino @C:\Users\user\.platformio\packages\framework-arduino-mbed\variants\RASPBERRY_PI_PICO\includes.txt -nostdlib -DPLATFORMIO=60111 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_RP2040 -DARM_MATH_CM0PLUS -D__CMSIS_RTOS -DCOMPONENT_FLASHIAP=1 -D__CORTEX_M0PLUS -DDEVICE_ANALOGIN=1 -DDEVICE_FLASH=1 -DDEVICE_I2C=1 -DDEVICE_I2CSLAVE=1 -DDEVICE_INTERRUPTIN=1 -DDEVICE_PORT_IN=1 -DDEVICE_PORT_OUT=1 -DDEVICE_PWMOUT=1 -DDEVICE_RESET_REASON=1 -DDEVICE_RTC=1 -DDEVICE_SERIAL=1 -DDEVICE_SERIAL_FC=1 -DDEVICE_SPI=1 -DDEVICE_USBDEVICE=1 -DDEVICE_USTICKER=1 -DDEVICE_WATCHDOG=1 -D__MBED__=1 -DMBED_BUILD_TIMESTAMP=1700585028.014541 -D__MBED_CMSIS_RTOS_CM -DMBED_MPU_CUSTOM -DMBEDTLS_ENTROPY_NV_SEED -DPICO_NO_BINARY_INFO=1 -DPICO_ON_DEVICE=1 -DPICO_RP2040_USB_DEVICE_ENUMERATION_FIX=1 -DPICO_TIME_DEFAULT_ALARM_POOL_DISABLED -DPICO_UART_ENABLE_CRLF_SUPPORT=0 -DTARGET_CORTEX -DTARGET_CORTEX_M -DTARGET_LIKE_CORTEX_M0 -DTARGET_LIKE_MBED -DTARGET_M0P -DTARGET_memmap_default -DTARGET_NAME=RASPBERRY_PI_PICO -DTARGET_RASPBERRYPI -DTARGET_RASPBERRY_PI_PICO -DTARGET_RELEASE -DTARGET_RP2040 -DTOOLCHAIN_GCC -DTOOLCHAIN_GCC_ARM -DMBED_NO_GLOBAL_USING_DIRECTIVE=1 -DCORE_MAJOR=4 -DCORE_MINOR=0 -DCORE_PATCH=10 -DUSE_ARDUINO_PINOUT -DARDUINO=10810 -DARDUINO_ARCH_MBED -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino\api\deprecated -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino\api\deprecated-avr-comp -IC:\Users\user\.platformio\packages\framework-arduino-mbed\variants\RASPBERRY_PI_PICO C:\Users\user\.platformio\packages\framework-arduino-mbed\variants\RASPBERRY_PI_PICO\double_tap_usb_boot.cpp
arm-none-eabi-g++ -o .pio\build\pico\FrameworkArduinoVariant\variant.cpp.o -c -Wvla -fno-rtti -std=gnu++14 -Wno-ignored-qualifiers -Wno-nonnull -DMBED_TRAP_ERRORS_ENABLED=1 -Os -Wall -Wextra -Wno-missing-field-initializers -Wno-unused-parameter -c -fdata-sections -ffunction-sections -fmessage-length=0 -fno-exceptions -fomit-frame-pointer -funsigned-char -mcpu=cortex-m0plus -mthumb -iprefixC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino @C:\Users\user\.platformio\packages\framework-arduino-mbed\variants\RASPBERRY_PI_PICO\includes.txt -nostdlib -DPLATFORMIO=60111 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_RP2040 -DARM_MATH_CM0PLUS -D__CMSIS_RTOS -DCOMPONENT_FLASHIAP=1 -D__CORTEX_M0PLUS -DDEVICE_ANALOGIN=1 -DDEVICE_FLASH=1 -DDEVICE_I2C=1 -DDEVICE_I2CSLAVE=1 -DDEVICE_INTERRUPTIN=1 -DDEVICE_PORT_IN=1 -DDEVICE_PORT_OUT=1 -DDEVICE_PWMOUT=1 -DDEVICE_RESET_REASON=1 -DDEVICE_RTC=1 -DDEVICE_SERIAL=1 -DDEVICE_SERIAL_FC=1 -DDEVICE_SPI=1 -DDEVICE_USBDEVICE=1 -DDEVICE_USTICKER=1 -DDEVICE_WATCHDOG=1 -D__MBED__=1 -DMBED_BUILD_TIMESTAMP=1700585028.014541 -D__MBED_CMSIS_RTOS_CM -DMBED_MPU_CUSTOM -DMBEDTLS_ENTROPY_NV_SEED -DPICO_NO_BINARY_INFO=1 -DPICO_ON_DEVICE=1 -DPICO_RP2040_USB_DEVICE_ENUMERATION_FIX=1 -DPICO_TIME_DEFAULT_ALARM_POOL_DISABLED -DPICO_UART_ENABLE_CRLF_SUPPORT=0 -DTARGET_CORTEX -DTARGET_CORTEX_M -DTARGET_LIKE_CORTEX_M0 -DTARGET_LIKE_MBED -DTARGET_M0P -DTARGET_memmap_default -DTARGET_NAME=RASPBERRY_PI_PICO -DTARGET_RASPBERRYPI -DTARGET_RASPBERRY_PI_PICO -DTARGET_RELEASE -DTARGET_RP2040 -DTOOLCHAIN_GCC -DTOOLCHAIN_GCC_ARM -DMBED_NO_GLOBAL_USING_DIRECTIVE=1 -DCORE_MAJOR=4 -DCORE_MINOR=0 -DCORE_PATCH=10 -DUSE_ARDUINO_PINOUT -DARDUINO=10810 -DARDUINO_ARCH_MBED -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino\api\deprecated -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino\api\deprecated-avr-comp -IC:\Users\user\.platformio\packages\framework-arduino-mbed\variants\RASPBERRY_PI_PICO C:\Users\user\.platformio\packages\framework-arduino-mbed\variants\RASPBERRY_PI_PICO\variant.cpp
arm-none-eabi-g++ -o .pio\build\pico\FrameworkArduino\Interrupts.cpp.o -c -Wvla -fno-rtti -std=gnu++14 -Wno-ignored-qualifiers -Wno-nonnull -DMBED_TRAP_ERRORS_ENABLED=1 -Os -Wall -Wextra -Wno-missing-field-initializers -Wno-unused-parameter -c -fdata-sections -ffunction-sections -fmessage-length=0 -fno-exceptions -fomit-frame-pointer -funsigned-char -mcpu=cortex-m0plus -mthumb -iprefixC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino @C:\Users\user\.platformio\packages\framework-arduino-mbed\variants\RASPBERRY_PI_PICO\includes.txt -nostdlib -DPLATFORMIO=60111 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_RP2040 -DARM_MATH_CM0PLUS -D__CMSIS_RTOS -DCOMPONENT_FLASHIAP=1 -D__CORTEX_M0PLUS -DDEVICE_ANALOGIN=1 -DDEVICE_FLASH=1 -DDEVICE_I2C=1 -DDEVICE_I2CSLAVE=1 -DDEVICE_INTERRUPTIN=1 -DDEVICE_PORT_IN=1 -DDEVICE_PORT_OUT=1 -DDEVICE_PWMOUT=1 -DDEVICE_RESET_REASON=1 -DDEVICE_RTC=1 -DDEVICE_SERIAL=1 -DDEVICE_SERIAL_FC=1 -DDEVICE_SPI=1 -DDEVICE_USBDEVICE=1 -DDEVICE_USTICKER=1 -DDEVICE_WATCHDOG=1 -D__MBED__=1 -DMBED_BUILD_TIMESTAMP=1700585028.014541 -D__MBED_CMSIS_RTOS_CM -DMBED_MPU_CUSTOM -DMBEDTLS_ENTROPY_NV_SEED -DPICO_NO_BINARY_INFO=1 -DPICO_ON_DEVICE=1 -DPICO_RP2040_USB_DEVICE_ENUMERATION_FIX=1 -DPICO_TIME_DEFAULT_ALARM_POOL_DISABLED -DPICO_UART_ENABLE_CRLF_SUPPORT=0 -DTARGET_CORTEX -DTARGET_CORTEX_M -DTARGET_LIKE_CORTEX_M0 -DTARGET_LIKE_MBED -DTARGET_M0P -DTARGET_memmap_default -DTARGET_NAME=RASPBERRY_PI_PICO -DTARGET_RASPBERRYPI -DTARGET_RASPBERRY_PI_PICO -DTARGET_RELEASE -DTARGET_RP2040 -DTOOLCHAIN_GCC -DTOOLCHAIN_GCC_ARM -DMBED_NO_GLOBAL_USING_DIRECTIVE=1 -DCORE_MAJOR=4 -DCORE_MINOR=0 -DCORE_PATCH=10 -DUSE_ARDUINO_PINOUT -DARDUINO=10810 -DARDUINO_ARCH_MBED -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino\api\deprecated -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino\api\deprecated-avr-comp -IC:\Users\user\.platformio\packages\framework-arduino-mbed\variants\RASPBERRY_PI_PICO C:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino\Interrupts.cpp
arm-none-eabi-g++ -o .pio\build\pico\FrameworkArduino\Serial.cpp.o -c -Wvla -fno-rtti -std=gnu++14 -Wno-ignored-qualifiers -Wno-nonnull -DMBED_TRAP_ERRORS_ENABLED=1 -Os -Wall -Wextra -Wno-missing-field-initializers -Wno-unused-parameter -c -fdata-sections -ffunction-sections -fmessage-length=0 -fno-exceptions -fomit-frame-pointer -funsigned-char -mcpu=cortex-m0plus -mthumb -iprefixC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino @C:\Users\user\.platformio\packages\framework-arduino-mbed\variants\RASPBERRY_PI_PICO\includes.txt -nostdlib -DPLATFORMIO=60111 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_RP2040 -DARM_MATH_CM0PLUS -D__CMSIS_RTOS -DCOMPONENT_FLASHIAP=1 -D__CORTEX_M0PLUS -DDEVICE_ANALOGIN=1 -DDEVICE_FLASH=1 -DDEVICE_I2C=1 -DDEVICE_I2CSLAVE=1 -DDEVICE_INTERRUPTIN=1 -DDEVICE_PORT_IN=1 -DDEVICE_PORT_OUT=1 -DDEVICE_PWMOUT=1 -DDEVICE_RESET_REASON=1 -DDEVICE_RTC=1 -DDEVICE_SERIAL=1 -DDEVICE_SERIAL_FC=1 -DDEVICE_SPI=1 -DDEVICE_USBDEVICE=1 -DDEVICE_USTICKER=1 -DDEVICE_WATCHDOG=1 -D__MBED__=1 -DMBED_BUILD_TIMESTAMP=1700585028.014541 -D__MBED_CMSIS_RTOS_CM
-DMBED_MPU_CUSTOM -DMBEDTLS_ENTROPY_NV_SEED -DPICO_NO_BINARY_INFO=1 -DPICO_ON_DEVICE=1 -DPICO_RP2040_USB_DEVICE_ENUMERATION_FIX=1 -DPICO_TIME_DEFAULT_ALARM_POOL_DISABLED -DPICO_UART_ENABLE_CRLF_SUPPORT=0 -DTARGET_CORTEX -DTARGET_CORTEX_M -DTARGET_LIKE_CORTEX_M0 -DTARGET_LIKE_MBED -DTARGET_M0P -DTARGET_memmap_default -DTARGET_NAME=RASPBERRY_PI_PICO -DTARGET_RASPBERRYPI -DTARGET_RASPBERRY_PI_PICO -DTARGET_RELEASE -DTARGET_RP2040 -DTOOLCHAIN_GCC -DTOOLCHAIN_GCC_ARM -DMBED_NO_GLOBAL_USING_DIRECTIVE=1 -DCORE_MAJOR=4 -DCORE_MINOR=0 -DCORE_PATCH=10 -DUSE_ARDUINO_PINOUT -DARDUINO=10810 -DARDUINO_ARCH_MBED -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino\api\deprecated -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino\api\deprecated-avr-comp -IC:\Users\user\.platformio\packages\framework-arduino-mbed\variants\RASPBERRY_PI_PICO C:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino\Serial.cpp
arm-none-eabi-g++ -o .pio\build\pico\FrameworkArduino\Tone.cpp.o -c -Wvla -fno-rtti -std=gnu++14 -Wno-ignored-qualifiers -Wno-nonnull -DMBED_TRAP_ERRORS_ENABLED=1 -Os -Wall -Wextra -Wno-missing-field-initializers -Wno-unused-parameter -c -fdata-sections -ffunction-sections -fmessage-length=0 -fno-exceptions -fomit-frame-pointer -funsigned-char -mcpu=cortex-m0plus -mthumb -iprefixC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino @C:\Users\user\.platformio\packages\framework-arduino-mbed\variants\RASPBERRY_PI_PICO\includes.txt -nostdlib -DPLATFORMIO=60111 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_RP2040 -DARM_MATH_CM0PLUS -D__CMSIS_RTOS -DCOMPONENT_FLASHIAP=1 -D__CORTEX_M0PLUS -DDEVICE_ANALOGIN=1 -DDEVICE_FLASH=1 -DDEVICE_I2C=1 -DDEVICE_I2CSLAVE=1 -DDEVICE_INTERRUPTIN=1 -DDEVICE_PORT_IN=1 -DDEVICE_PORT_OUT=1 -DDEVICE_PWMOUT=1 -DDEVICE_RESET_REASON=1 -DDEVICE_RTC=1 -DDEVICE_SERIAL=1 -DDEVICE_SERIAL_FC=1 -DDEVICE_SPI=1 -DDEVICE_USBDEVICE=1 -DDEVICE_USTICKER=1 -DDEVICE_WATCHDOG=1 -D__MBED__=1 -DMBED_BUILD_TIMESTAMP=1700585028.014541 -D__MBED_CMSIS_RTOS_CM -DMBED_MPU_CUSTOM -DMBEDTLS_ENTROPY_NV_SEED -DPICO_NO_BINARY_INFO=1 -DPICO_ON_DEVICE=1 -DPICO_RP2040_USB_DEVICE_ENUMERATION_FIX=1 -DPICO_TIME_DEFAULT_ALARM_POOL_DISABLED -DPICO_UART_ENABLE_CRLF_SUPPORT=0 -DTARGET_CORTEX -DTARGET_CORTEX_M -DTARGET_LIKE_CORTEX_M0 -DTARGET_LIKE_MBED -DTARGET_M0P -DTARGET_memmap_default -DTARGET_NAME=RASPBERRY_PI_PICO -DTARGET_RASPBERRYPI -DTARGET_RASPBERRY_PI_PICO -DTARGET_RELEASE -DTARGET_RP2040 -DTOOLCHAIN_GCC -DTOOLCHAIN_GCC_ARM -DMBED_NO_GLOBAL_USING_DIRECTIVE=1 -DCORE_MAJOR=4 -DCORE_MINOR=0 -DCORE_PATCH=10
-DUSE_ARDUINO_PINOUT -DARDUINO=10810 -DARDUINO_ARCH_MBED -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino\api\deprecated -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino\api\deprecated-avr-comp -IC:\Users\user\.platformio\packages\framework-arduino-mbed\variants\RASPBERRY_PI_PICO C:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino\Tone.cpp
arm-none-eabi-g++ -o .pio\build\pico\FrameworkArduino\USB\PluggableUSBDevice.cpp.o -c -Wvla -fno-rtti -std=gnu++14 -Wno-ignored-qualifiers -Wno-nonnull -DMBED_TRAP_ERRORS_ENABLED=1 -Os -Wall -Wextra -Wno-missing-field-initializers -Wno-unused-parameter -c -fdata-sections -ffunction-sections -fmessage-length=0 -fno-exceptions -fomit-frame-pointer -funsigned-char
-mcpu=cortex-m0plus -mthumb -iprefixC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino @C:\Users\user\.platformio\packages\framework-arduino-mbed\variants\RASPBERRY_PI_PICO\includes.txt -nostdlib -DPLATFORMIO=60111 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_RP2040 -DARM_MATH_CM0PLUS -D__CMSIS_RTOS -DCOMPONENT_FLASHIAP=1 -D__CORTEX_M0PLUS -DDEVICE_ANALOGIN=1 -DDEVICE_FLASH=1 -DDEVICE_I2C=1 -DDEVICE_I2CSLAVE=1 -DDEVICE_INTERRUPTIN=1 -DDEVICE_PORT_IN=1 -DDEVICE_PORT_OUT=1 -DDEVICE_PWMOUT=1 -DDEVICE_RESET_REASON=1 -DDEVICE_RTC=1 -DDEVICE_SERIAL=1 -DDEVICE_SERIAL_FC=1 -DDEVICE_SPI=1 -DDEVICE_USBDEVICE=1 -DDEVICE_USTICKER=1 -DDEVICE_WATCHDOG=1 -D__MBED__=1 -DMBED_BUILD_TIMESTAMP=1700585028.014541 -D__MBED_CMSIS_RTOS_CM -DMBED_MPU_CUSTOM -DMBEDTLS_ENTROPY_NV_SEED -DPICO_NO_BINARY_INFO=1 -DPICO_ON_DEVICE=1 -DPICO_RP2040_USB_DEVICE_ENUMERATION_FIX=1 -DPICO_TIME_DEFAULT_ALARM_POOL_DISABLED -DPICO_UART_ENABLE_CRLF_SUPPORT=0 -DTARGET_CORTEX -DTARGET_CORTEX_M -DTARGET_LIKE_CORTEX_M0 -DTARGET_LIKE_MBED -DTARGET_M0P -DTARGET_memmap_default -DTARGET_NAME=RASPBERRY_PI_PICO -DTARGET_RASPBERRYPI -DTARGET_RASPBERRY_PI_PICO -DTARGET_RELEASE -DTARGET_RP2040 -DTOOLCHAIN_GCC -DTOOLCHAIN_GCC_ARM -DMBED_NO_GLOBAL_USING_DIRECTIVE=1 -DCORE_MAJOR=4 -DCORE_MINOR=0 -DCORE_PATCH=10 -DUSE_ARDUINO_PINOUT -DARDUINO=10810 -DARDUINO_ARCH_MBED -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino\api\deprecated -IC:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino\api\deprecated-avr-comp -IC:\Users\user\.platformio\packages\framework-arduino-mbed\variants\RASPBERRY_PI_PICO C:\Users\user\.platformio\packages\framework-arduino-mbed\cores\arduino\USB\PluggableUSBDevice.cpp
src\main.cpp:1:10: fatal error: Adafruit_TinyUSB.h: No such file or directory
* Looking for Adafruit_TinyUSB.h dependency? Check our library registry!
* CLI > platformio lib search "header:Adafruit_TinyUSB.h"
* Web > https://registry.platformio.org/search?q=header:Adafruit_TinyUSB.h
1 | #include <Adafruit_TinyUSB.h>
compilation terminated.
*** [.pio\build\pico\src\main.cpp.o] Error 1
============================================================================ [FAILED] Took 20.10 seconds ============================================================================
* The terminal process "C:\Users\user\.platformio\penv\Scripts\platformio.exe 'run', '--verbose', '--environment', 'pico'" terminated with exit code: 1.
