Im a student trying to read the temperature on a generic BLE Beacon using a ESP32-WROOM-32U. When i use the BLE client example on the Arduino IDE Version 1.8.19 using the native lib “ESP32 BLE Arduino” it works well, read the temp, all ok.
But when i upload the exactly same code using VsCode 1.69.1 and the same lib “ESP32 BLE Arduino” Version 2.0.0, compile and upload, but when it run, i get this error:
Forming a connection to d4:b4:96:29:d5:b0
- Created client
- Connected to server
Guru Meditation Error: Core 0 panic'ed (Unhandled debug exception).
Debug exception reason: Stack canary watchpoint triggered (BTU_TASK)
Core 0 register dump:
PC : 0x40094f33 PS : 0x00060b36 A0 : 0x80096c48 A1 : 0x3ffd0310
A2 : 0x3ffb6c34 A3 : 0xb33fffff A4 : 0x0000abab A5 : 0x00060b23
A6 : 0x00060b23 A7 : 0x0000cdcd A8 : 0x0000cdcd A9 : 0xffffffff
A10 : 0x00000000 A11 : 0x00000000 A12 : 0x00000008 A13 : 0x00000008
A14 : 0x007b6c34 A15 : 0x003fffff SAR : 0x0000001a EXCCAUSE: 0x00000001
EXCVADDR: 0x00000000 LBEG : 0x4008fd48 LEND : 0x4008fd5e LCOUNT : 0x00000000
Backtrace:0x40094f30:0x3ffd03100x40096c45:0x3ffd0350 0x40096c6f:0x3ffd0370 0x40096ebc:0x3ffd0390 0x400834c6:0x3ffd03b0 0x400834d9:0x3ffd03e0 0x40083509:0x3ffd0400 0x40097305:0x3ffd0420 0x40097320:0x3ffd0440 0x401125c1:0x3ffd0460 0x40111d95:0x3ffd0480 0x40105149:0x3ffd04a0 0x401040b3:0x3ffd04c0 0x40128c41:0x3ffd04f0 0x40128d8f:0x3ffd0510 0x40128ed2:0x3ffd0530 0x400fbe25:0x3ffd0570 0x400fb295:0x3ffd0800 0x40115612:0x3ffd0820 0x40115750:0x3ffd0860 0x40115afa:0x3ffd0880 0x40115bb9:0x3ffd0b10 0x40115bd7:0x3ffd0b30 0x40115b9f:0x3ffd0b50 0x40115bd7:0x3ffd0b70 0x40115b9f:0x3ffd0b90 0x40115bd7:0x3ffd0bb0 0x40115b9f:0x3ffd0bd0 0x40115bd7:0x3ffd0bf0 0x40115b9f:0x3ffd0c10 0x40115bd7:0x3ffd0c30 0x40115b9f:0x3ffd0c50 0x40115bd7:0x3ffd0c70 0x40115b9f:0x3ffd0c90 0x40115cf6:0x3ffd0cb0 0x40100af1:0x3ffd0cd0 0x400fbe5e:0x3ffd0f70 0x400fc309:0x3ffd1200 0x400fccc1:0x3ffd1260 0x400fdffc:0x3ffd12a0 0x400fe032:0x3ffd12c0 0x40109299:0x3ffd12e0 0x400f9e18:0x3ffd1470 0x40112977:0x3ffd1490
ELF file SHA256: 0000000000000000
Rebooting...
I understand that in someway my code is making a stackoverflow, i already tried to modify the partition scheme using this https://geekelectronick.com/esp32-customizing-partition-in-platformio/ and reducing the massive use of serial.print but dont work.
I tried some of the tips here https://github.com/nkolban/esp32-snippets/issues/874 but dont work too.
The configuration on platformio.ini:
Below the code im using:
* A BLE client example that is rich in capabilities.
* There is a lot new capabilities implemented.
* author unknown
* updated by chegewara
#include "arduino.h"
#include "BLEDevice.h"
// The remote service we wish to connect to.
static BLEUUID serviceUUID("0000AA20");
// The characteristic of the remote service we are interested in.
static BLEUUID charUUID("0000AA21");
String addr = String("d4:b4:96:29:d5:b0");
static boolean doConnect = false;
static boolean connected = false;
static boolean doScan = false;
static BLERemoteCharacteristic* pRemoteCharacteristic;
static BLEAdvertisedDevice* myDevice;
static void notifyCallback(
BLERemoteCharacteristic* pBLERemoteCharacteristic,
uint8_t* pData,
size_t length,
bool isNotify) {
Serial.print("Notify callback for characteristic ");
Serial.print(pBLERemoteCharacteristic->getUUID().toString().c_str());
Serial.print(" of data length ");
Serial.println(length);
Serial.print("data: ");
Serial.println((char*)pData);
class MyClientCallback : public BLEClientCallbacks {
void onConnect(BLEClient* pclient) {
void onDisconnect(BLEClient* pclient) {
connected = false;
Serial.println("onDisconnect");
bool connectToServer() {
Serial.print("Forming a connection to ");
Serial.println(myDevice->getAddress().toString().c_str());
BLEClient* pClient = BLEDevice::createClient();
Serial.println(" - Created client");
pClient->setClientCallbacks(new MyClientCallback());
// Connect to the remove BLE Server.
pClient->connect(myDevice); // if you pass BLEAdvertisedDevice instead of address, it will be recognized type of peer device address (public or private)
Serial.println(" - Connected to server");
// Obtain a reference to the service we are after in the remote BLE server.
BLERemoteService* pRemoteService = pClient->getService(serviceUUID);
if (pRemoteService == nullptr) {
Serial.print("Failed to find our service UUID: ");
Serial.println(serviceUUID.toString().c_str());
pClient->disconnect();
return false;
Serial.println(" - Found our service");
// Obtain a reference to the characteristic in the service of the remote BLE server.
pRemoteCharacteristic = pRemoteService->getCharacteristic(charUUID);
if (pRemoteCharacteristic == nullptr) {
Serial.print("Failed to find our characteristic UUID: ");
Serial.println(charUUID.toString().c_str());
return false;
Serial.println(" - Found our characteristic");
// Read the value of the characteristic.
if(pRemoteCharacteristic->canRead()) {
std::string value = pRemoteCharacteristic->readValue();
Serial.print("The characteristic value was: ");
Serial.println(value.c_str());
if(pRemoteCharacteristic->canNotify())
pRemoteCharacteristic->registerForNotify(notifyCallback);
connected = true;
return true;
* Scan for BLE servers and find the first one that advertises the service we are looking for.
class MyAdvertisedDeviceCallbacks: public BLEAdvertisedDeviceCallbacks {
* Called for each advertising BLE server.
void onResult(BLEAdvertisedDevice advertisedDevice) {
Serial.print("BLE Advertised Device found: ");
Serial.println(advertisedDevice.toString().c_str());
String result = advertisedDevice.getAddress().toString().c_str();
// We have found a device, let us now see if it contains the service we are looking for.
if (advertisedDevice.haveServiceUUID() && advertisedDevice.isAdvertisingService(serviceUUID) && result.compareTo(addr)==0) {
BLEDevice::getScan()->stop();
myDevice = new BLEAdvertisedDevice(advertisedDevice);
doConnect = true;
doScan = true;
} // Found our server
} // onResult
}; // MyAdvertisedDeviceCallbacks
Serial.println("Starting Arduino BLE Client application...");
BLEDevice::init("");
// Retrieve a Scanner and set the callback we want to use to be informed when we
// have detected a new device. Specify that we want active scanning and start the
// scan to run for 5 seconds.
BLEScan* pBLEScan = BLEDevice::getScan();
pBLEScan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks());
pBLEScan->setInterval(1349);
pBLEScan->setWindow(449);
pBLEScan->setActiveScan(true);
pBLEScan->start(60, false);
} // End of setup.
// This is the Arduino main loop function.
// If the flag "doConnect" is true then we have scanned for and found the desired
// BLE Server with which we wish to connect. Now we connect to it. Once we are
// connected we set the connected flag to be true.
if (doConnect == true) {
if (connectToServer()) {
Serial.println("We are now connected to the BLE Server.");
} else {
Serial.println("We have failed to connect to the server; there is nothin more we will do.");
doConnect = false;
// If we are connected to a peer BLE Server, update the characteristic each time we are reached
// with the current time since boot.
if (connected) {
String newValue = "Canopus: " + String(millis()/1000);
pRemoteCharacteristic->writeValue(newValue.c_str(), newValue.length());
Serial.print("\r\n - Result sensor");
Serial.printf("\r\nLength : %d\r\n", value.length());
Serial.print(" 0x"); Serial.print((uint8_t)value[0], HEX);
Serial.print(" 0x"); Serial.print((uint8_t)value[1], HEX);
Serial.print(" 0x"); Serial.print((uint8_t)value[2], HEX);
Serial.print(" 0x"); Serial.print((uint8_t)value[3], HEX);
Serial.print(" 0x"); Serial.print((uint8_t)value[4], HEX);
Serial.print(" 0x"); Serial.print((uint8_t)value[5], HEX);
float temp = value[1]*100+value[2];
if(value[1]==1)
temp=temp*-1;
Serial.printf("\r\nTemp: %.02f*C", temp/100);
float humi = value[4]*100+value[5];
Serial.printf("\r\nHumi: %.02f/%", humi/100);
}else if(doScan){
BLEDevice::getScan()->start(0); // this is just example to start scan after disconnect, most likely there is better way to do it in arduino
delay(10); // Delay a second between loops.
} // End of loop
