I added a dependency to lib_deps in platformio.ini:
adafruit/Adafruit MCP23017 Arduino Library@^2.1.0
Then I ran “pio run” from the command line to compile it.
I got a bunch of errors about not being able to find headers for Adafruiit_BusIO (which is a dependency). The error messages suggest adding it as a dependency, so I did, but it didn’t help; then it complains about not being able to find Wire.h.
If I then add the include to main:
#include <Adafruit_MCP23X08.h>
Then everything compiles fine, even though I removed the dependency on BusIO. Comment it out, and everything is broken again.
This behavior is puzzling. Why should commenting out an unused #include break things? I’m getting compile errors in code that I’m not actually using. Why is it compiled at all?
Also, why can PlatformIO find the dependency of a dependency when the #include is there, but it can’t find it if it’s not there?
Also, where in the documentation does it explain how the build system works?
