I include my ‘storage.h’ header file in several .cpp files. I thought I had done this correct but something not right…
using #ifndef , #define and #else to route the header accordingly with the definitions only occurring on the first call of the header. Otherwise the externs are used.
#define EE_ADDRESS_storedfrequency 0
#ifndef STORAGE_H
#define STORAGE_H
byte lightmode;
#else
extern byte lightmode;
This won’t work. The define guards are there to guard against multiple inclusion per compilation unit.
Conside the file file1.cpp where you do
#include <lib1.h>
#include <lib2.h>
and consider that both header files do a #include <common.h>. Now with the standard include guard
#ifndef COMMON_H
#define COMMON_H
/* stuff */
Then if lib1.h is included, common.h is included too with the inner “stuff” being activate. Then lib2.h is included, which causes again common.h to be included but now it doesn’t define all its stuff again because of the include guards.
The same will repeat if you have a file2.cpp which includes the two header fiels as well.
Meaning that if you do a global variable definition with byte lightmode;in the inside of the include guard, you will indeed only include it once per .cpp file, but with multiple cpp files, the definition will still be there in multiple .cpp files, thus leading to the multiple definition error.
The right way is to only extern byte lightmode; in the header file and then define the variable with byte lightmode; in only one cpp file.
Yes… I get it… per compilation unit makes sense.
I was shown this technique many many years ago, and have somehow used it successfully when working with the C166 processor in the Keil IDE. I don’t know if somehow the defines were retained throughout the project build… I need to see if I can find the original docs out of interest,
