Hi i’m using some boards from DF-Robot “Fire Beetle” ESP-8266 type.
link here: FireBeetle ESP8266 IoT MCU - DFR0489 | DFRobot Electronics.
There are no “fire beetle” boards in the list of boards.
Which board should i use?
kind regards
daniel
kind regards
daniel
Looks like it’s mostly the same as nodemcuv2, maybe this configuration will work, however it requires some research. You can define custom board if tweaking some of parameters is required.
You can look at boards.txt
located in this zip file.
cheers kolen,
i shall investigate further. thank you for the pointers.
kind regards daniel
