Where is the HID library?
I am working on a project using an ESP32C3 to emulate a keyboard. I have included the arduino Keyboard library in my ini file, but build fails on failing to find HID.h. I cannot find out how to install any HID library.
The Arduino-ESP32 features no HID.h library. Still, USB keyboard or mouse functionality is available as USBHIDKeyboard.h.
Max, thank you for your response. Perhaps you could assist me further.
My main.cpp is as follows:
#include Arduino (within angle brackets, of course)
#include “USBHIDKeyboard.h”
#include “USB.h”
USBHIDKeyboard Keyboard:
Keyboard.begin();
USB.begin();
void loop() {}
Executing Platformio Build, the compiler reports ‘USBHIDKeyboard’ does not name a type, and, unsurprisingly, that Keyboard and USB were not declared in this scope.
Any thoughtn
Whats your exact platformio.ini?
Again, thank you for taking the time for this.
Platformio.ini:
[env:seeed_xiao_esp32c3]
board = seed_xiao_esp32c3
Also, in anticipation:
  • framework-arduinoespressif32 @ 3.20009.0 (2.0.9)
  • tool-esptoolpy @ 1.40501.0 (4.5.1)
  • toolchain-riscv32-esp @ 8.4.0+202lr2-patch5
You’re on an old version, update to espressif32 6.6.0.
CLI →
pio pkg update -g -p espressif32
or platform = espressif32@6.6.0 in the pltaformio.ini
Hi Max!
Well…
platformio.ini:
; Redirecting...
board = seeed_xiao_esp32c3
main.cpp:
#include “USB.h”
USBHIDKeyboard Keyboard;
pinMode(0, INPUT_PULLUP);
Keyboard.begin();
USB.begin();
build:
Executing task: platformio run --environment seeed_xiao_esp32c3
Processing seeed_xiao_esp32c3 (platform: espressif32@6.6.0; board: seeed_xiao_esp32c3; framework: arduino)
CONFIGURATION: ***
PLATFORM: Espressif 32 (6.6.0) > Seeed Studio XIAO ESP32C3
HARDWARE: ESP32C3 160MHz, 320KB RAM, 4MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-builtin, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
  • framework-arduinoespressif32 @ 3.20014.231204 (2.0.14)
  • toolchain-riscv32-esp @ 8.4.0+2021r2-patch5
    Found 33 compatible libraries
    Scanning dependencies…
    |-- USB @ 2.0.0
    Compiling .pio/build/seeed_xiao_esp32c3/src/main.cpp.o
    Building .pio/build/seeed_xiao_esp32c3/bootloader.bin
    Generating partitions .pio/build/seeed_xiao_esp32c3/partitions.bin
    esptool.py v4.5.1
    Creating esp32c3 image…
    Merged 1 ELF section
    Successfully created esp32c3 image.
    Compiling .pio/build/seeed_xiao_esp32c3/lib4f0/USB/USBHID.cpp.o
    Compiling .pio/build/seeed_xiao_esp32c3/lib4f0/USB/USBHIDConsumerControl.cpp.o
    Compiling .pio/build/seeed_xiao_esp32c3/lib4f0/USB/USBHIDGamepad.cpp.o
    Compiling .pio/build/seeed_xiao_esp32c3/lib4f0/USB/USBHIDKeyboard.cpp.o
    Compiling .pio/build/seeed_xiao_esp32c3/lib4f0/USB/USBHIDMouse.cpp.o
    Compiling .pio/build/seeed_xiao_esp32c3/lib4f0/USB/USBHIDSystemControl.cpp.o
    Compiling .pio/build/seeed_xiao_esp32c3/lib4f0/USB/USBHIDVendor.cpp.o
    Compiling .pio/build/seeed_xiao_esp32c3/lib4f0/USB/USBVendor.cpp.o
    src/main.cpp:5:1: error: ‘USBHIDKeyboard’ does not name a type
    src/main.cpp: In function ‘void setup()’:
    src/main.cpp:9:3: error: ‘Keyboard’ was not declared in this scope
    Keyboard.begin();
    src/main.cpp:10:3: error: ‘USB’ was not declared in this scope
    USB.begin();
    Compiling .pio/build/seeed_xiao_esp32c3/FrameworkArduino/Esp.cpp.o
    *** [.pio/build/seeed_xiao_esp32c3/src/main.cpp.o] Error 1
Oh, my bad, it’s a ESP32C3? That chip does not have a freely programmable USB peripheral. Its function is fixed to USB CDC (Serial) and JTAG.
https://docs.espressif.com/projects/esp-idf/en/stable/esp32c3/get-started/establish-serial-connection.html#flash-using-usb
The ESP32S3 would support it. See all the .skip.X files in https://github.com/espressif/arduino-esp32/tree/master/libraries/USB/examples/Keyboard/KeyboardMessage to skip the incompatible boards.
Same is said in
https://github.com/adafruit/circuitpython/issues/8062
Oh well…
Perhaps you could advise me on another matter. I installed VSCode, then installed the Platformio extension which, it was my understanding, would also install the Platformio CLI. But, when I access the Platform Core CLI and enter “pio --help” I am told that ‘pio’ is not found but can be installed with: sudo apt install platformio
Don’t install PlatformIO via apt. You can expose the pio commands to the regular shell as documented.
https://docs.platformio.org/en/latest/core/installation/shell-commands.html
So, is there a way to get the CLI without apt? (Oh, wait, I wasn’t looking in the page you referenced)
(And, by the way, I do have a couple of S3 boards, and, reconfiguring, I got successful build)
