I’m going through the Zephyr examples (e.g. this) with an Adafruit Bluefruit nRF52832 Feather and just using the CLI (I’m using Emacs, not VS Code).
It works, but I’m a bit confused about the printing. Where does printk print? There’s no serial port available, if I run pio device monitor, then it just prints:
--- Available filters and text transformations: colorize, debug, default, direct, hexlify, log2file, nocontrol, printable, send_on_enter, time
--- More details at http://bit.ly/pio-monitor-filters
--- Available ports:
--- Enter port index or full name:
Uhm, the board does have a USB-serial converter on board (schematics from adafruit). A CP2104. If you plug in the device via USB, that thing must show up. How did you upload the code in the first place? Can you show a picture of your board?
Sorry for the confusion, I meant that the serial port doesn’t show up on the computer.
For the Zephyr code I used a J-link to upload the code (blinky, BLE example).
I also used the Arduino framework earlier with the adafruit-nrfutil tool that uses the USB to flash the board, and ttyACM0 came up properly that time.
Here’s a photo of the board:
Well but if you upload via JLink then you don’t have a serial port, since printf probably goes out the hardware UART that in turn goes to the USB-serial adapter? Have you tried reading from the USB serial?
