I see this from time to time. What is it?
What do I do when this happens?
Hm. This is a second python thing posting, I guess the other didn’t stick.
901 errors now, up from 876, down from >1K. Up from one, which was failure to find a .exe file I found in the location is was supposed to be looking.
Processing wemos_d1_mini32 (platform: espressif32; board: wemos_d1_mini32; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/wemos_d1_mini32.html
PLATFORM: Espressif 32 (2.0.0) > WeMos D1 MINI ESP32
Library Manager: Installing Arduino
Library Manager: Warning! More than one package has been found by Arduino requirements:
- mbed-aluqard/arduino @ 0.0.0+sha.3b83fc30bbdf
- mbed-eduardog26/Arduino @ 0.0.0-alpha+sha.abbc3308dfa1
- mbed-thechrisyd/Arduino @ 0.0.0+sha.272d0276d474
- mbed-gastonfeng/arduino @ 0.0.0-alpha+sha.b000674ff8b3
- mbed-rahulsitaram/Arduino @ 0.0.0+sha.d0b32a4209f0
- mbed-team2/Arduino @ 0.0.0+sha.d96590319bcf
Library Manager: Please specify detailed REQUIREMENTS using package owner and version (showed above) to avoid name conflicts
Library Manager: arduino @ 0.0.0+sha.3b83fc30bbdf has been installed!
Library Manager: Installing Adafruit/Adafruit Sensor Library
KeyError: 'versions':
File "C:\Users\joema\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 169:
File "C:\Users\joema\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Script\SConscript.py", line 598:
File "C:\Users\joema\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Script\SConscript.py", line 287:
File "C:\Users\joema\.platformio\platforms\espressif32\builder\main.py", line 223:
File "C:\Users\joema\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Environment.py", line 219:
File "C:\Users\joema\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 62:
env.ProcessProjectDeps()
File "C:\Users\joema\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 140:
project_lib_builder = env.ConfigureProjectLibBuilder()
File "C:\Users\joema\.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py", line 1062:
project.install_dependencies()
File "C:\Users\joema\.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py", line 898:
lm.install(spec)
File "c:\users\joema\.platformio\penv\lib\site-packages\platformio\package\manager\_install.py", line 49:
spec, silent=silent, skip_dependencies=skip_dependencies, force=force
File "c:\users\joema\.platformio\penv\lib\site-packages\platformio\package\manager\library.py", line 86:
force=force,
File "c:\users\joema\.platformio\penv\lib\site-packages\platformio\package\manager\_install.py", line 99:
pkg = self.install_from_registry(spec, search_filters, silent=silent)
File "c:\users\joema\.platformio\penv\lib\site-packages\platformio\package\manager\_registry.py", line 86:
version = self.pick_best_registry_version(package["versions"], spec)
==================================================================================================== [FAILED]
Where is the bulltetproof installation that installs everything correcly?
Github?
You are being asked to fix your lub_deps
and supply library names in the given format of supplier/library_name
. You need to pick one of the listed Arduio libraries which is compatible with your device, and enter its full name in lib_deps
. This is new behaviour in the 5.0.0 release which you appear to be running. It fixes this problem with multiple libraries with the same name.
That was a clue!
That was/is explained in the release notes for 5.0.0. It’s on the forum home page under the Announcements forum.
Cheers,
Norm.
What platformio.ini
do you have so that it attempts installation of the Arduino core… while using the Arduino core? o_O
From his post above:
Cheers,
Norm.
