Please what the solution of this problem :
PIO Core Call Error: "Resolving esp32dev dependencies…\r\nTool Manager: Installing espressif/toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5\r\nDownloading 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100%\r\nUnpacking 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100%\r\nTool Manager: toolchain-xtensa-esp32@8.4.0+2021r2-patch5 has been installed!\r\nTool Manager: Installing platformio/framework-arduinoespressif32 @ ~3.20014.0\r\nDownloading 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100%\r\nUnpacking 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100%\r\nTool Manager: framework-arduinoespressif32@3.20014.231204 has been installed!\r\nTool Manager: Installing platformio/framework-espidf @ ~3.40406.0\r\nDownloading 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100%\r\nUnpacking 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100%\r\nTool Manager: framework-espidf@3.40406.240122 has been installed!\r\nAlready up-to-date.\r\nUpdating metadata for the vscode IDE…\r\n\n\nUserSideException: Processing esp32dev (board: esp32dev; platform: espressif32; framework: arduino, espidf)\r\n--------------------------------------------------------------------------------\r\nVerbose mode can be enabled via
-v, --verbose
option\r\nCONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32dev.html\r\nPLATFORM: Espressif 32 (6.5.0) > Espressif ESP32 Dev Module\r\nHARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash\r\nDEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)\r\nPACKAGES: \r\n - framework-arduinoespressif32 @ 3.20014.231204 (2.0.14) \r\n - framework-espidf @ 3.40406.240122 (4.4.6) \r\n - tool-cmake @ 3.16.4 \r\n - tool-esptoolpy @ 1.40501.0 (4.5.1) \r\n - tool-idf @ 1.0.1 \r\n - tool-mconf @ 1.4060000.20190628 (406.0.0) \r\n - tool-ninja @ 1.9.0 \r\n - toolchain-esp32ulp @ 1.23500.220830 (2.35.0) \r\n - toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5\r\nCreating a new virtual environment for IDF Python dependencies\r\nInstalling ESP-IDF’s Python dependencies\r\nCollecting urllib3<2\r\n Using cached https://files.pythonhosted.org/packages/b0/53/aa91e163dcfd1e5b82d8a890ecf13314e3e149c05270cc644581f77f17fd/urllib3-1.26.18-py2.py3-none-any.whl\r\nCollecting cryptography<35.0.0,>=2.1.4\r\n Downloading
