as title.
what is the specific #if defined(ARDUINO_ARCH_ESP32) for ESP32-S2, ESP32-S3, ESP32-C3?
I want to do something only if ESP32-S2 is used for example.
as title.
The ARDUINO_ARCH_ESP32 is the same for all ESP32-x chips, there is no ARDUINO_ARCH_ESP32_S2 for example.
However, you can use side-information from the sdkconfig.h that gets auto-included when you just #include <Arduino.h> and test for example for the following chip specific macros.
et cetara.
You can also see stuff like that happening in the core
thanks for the help, I really appreciate it.
I am trying this one:
#if defined(CONFIG_IDF_TARGET_ESP32C3)
root["board"] = "ESP32-C3";
#elif defined(CONFIG_IDF_TARGET_ESP32S2)
root["board"] = "ESP32-S2";
#elif defined(CONFIG_IDF_TARGET_ESP32S3)
root["board"] = "ESP32-S3";
#elif defined(ESP32)
root["board"] = "ESP32";
but it always ends up setting ESP32 even when using ESP32-S2.
ESP32 is again defined for all boards.
Can you try
#if CONFIG_IDF_TARGET_ESP32C3
#elif CONFIG_IDF_TARGET_ESP32S2
#elif CONFIG_IDF_TARGET_ESP32S3
#else
#error "Unrecognized ESP."
same thing, my root object contains ESP32…
I can’t reproduce that at all. When I add a snippet like
#warning "Compiling for ESP32-C3"
#warning "Compiling for ESP32-S2"
#warning "Compiling for ESP32-S3"
#warning "Compiling for ESP32"
#else
it’s clearly showing me only one bock activated
and that’s with
[env:lolin_s2_mini]
board = lolin_s2_mini
Can you add this snippet in your code somewhere and check if it triggers correctly in the build warning messages?
Are you sure you have put an #include <Arduino.h> before accessing those macros?
I’m using CLion from JetBrains with the PlatformIO plugin.
I reinited the project and now it works as expected.
thank you very much @maxgerhardt for the patience and for the help,
I really appreciate it ![]()
