platformio.ini:
[env:teensy41]
platform = teensy
board = teensy41
symlink://C:/Etc/Dev/Arduino/libraries/LittleFS
The problem is that I need to use the local copy of LittleFS at C:\Etc\Dev\Arduino\libraries since the FRAM chip I’m using to back the LittleFS filesystem isn’t supported in the built-in version of the library. Output from pio run -v is as follows:
Library Manager: Installing symlink://C:/Etc/Dev/Arduino/libraries/LittleFS
Library Manager: LittleFS@1.0.1 has been installed!
CONFIGURATION: https://docs.platformio.org/page/boards/teensy/teensy41.html
PLATFORM: Teensy (4.18.0) > Teensy 4.1
HARDWARE: IMXRT1062 600MHz, 512KB RAM, 7.75MB Flash
DEBUG: Current (jlink) External (jlink)
- framework-arduinoteensy @ 1.158.0 (1.58)
- tool-teensy @ 1.158.0 (1.58)
- toolchain-gccarmnoneeabi-teensy @ 1.110301.0 (11.3.1)
Found 96 compatible libraries
|-- LittleFS @ 1.0.0 (License: Unknown, Path: C:\Users\David\.platformio\packages\framework-arduinoteensy\libraries\LittleFS)
| |-- SPI @ 1.0 (License: Unknown, Path: C:\Users\David\.platformio\packages\framework-arduinoteensy\libraries\SPI)
|-- OctoWS2811 @ 1.5 (License: Unknown, Path: C:\Users\David\.platformio\packages\framework-arduinoteensy\libraries\OctoWS2811)
As can be seen, it has installed LittleFS from the local copy, but then when searching library dependencies, it’s still using the builtin one V 1.0.0.
How can I get pio run to explicitly use V1.0.1 of the library, so it’ll use the local copy that has support for the 4 Mb FRAM?
