Running pio run --list targets I see a whole list of targets available.
I see buildfs, uploadfs, and uploadfsota which I have never used. I have only every used erase and upload.
What do the others do? What should they be used for? I’m not finding any docs when I search on the site or google.
Thanks
uploadfs is directly documented in
https://docs.platformio.org/en/latest/platforms/espressif32.html#uploading-files-to-file-system
that’s the target name for (building and) uploading the filesystem binary. The targets are being created in platform-espressif32/builder/main.py.
So I understand, the fs notation indicates this is just the file system bit getting rebuilt or uploaded, not the firmware?
Example: if you have a partition table that looks like this
# Name, Type, SubType, Offset, Size, Flags
nvs, data, nvs, 0x9000, 0x5000,
otadata, data, ota, 0xe000, 0x2000,
app0, app, ota_0, 0x10000, 0x330000,
app1, app, ota_1, 0x340000,0x330000,
spiffs, data, spiffs, 0x670000,0x190000,
and you run uploadfs just the spiffs partition would be updated?
Yes. You can also see that in the flashing command visible when you’d do pio run -v -t uploadfs on the CLI.
