What am I doing wrong that I deserve this message?
--- 1. select Radio Task ---
--- 2. select Radio Task ---
Guru Meditation Error: Core 1 panic'ed (StoreProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x400d0ecb PS : 0x00060d30 A0 : 0x8008615c A1 : 0x3ffb87c0
A2 : 0x00000000 A3 : 0x00000001 A4 : 0x00000003 A5 : 0x00000000
A6 : 0x00000000 A7 : 0x00000000 A8 : 0x800d0ebe A9 : 0x3ffb8780
A10 : 0x00000001 A11 : 0x00000000 A12 : 0x3ffb8498 A13 : 0x00000000
A14 : 0x00000000 A15 : 0x3ffb875c SAR : 0x00000002 EXCCAUSE: 0x0000001d
EXCVADDR: 0x00000001 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xffffffff
ELF file SHA256: 0000000000000000
Backtrace: 0x400d0ecb:0x3ffb87c0 0x40086159:0x3ffb8820
Rebooting...
There isn’t very much in this tasks, so what’s going on that I don’t see (any more)?
void selectRadioTask(void *param)
Serial.printf("\n--- 1. select Radio Task ---\n");
// for-ever-loop
for (;;)
Serial.printf("--- 2. select Radio Task ---\n");
vTaskDelay(1000 / portTICK_PERIOD_MS);
} // end for-ever-loop()
} // end selectRadioTask()
Can you get this decoded with the same two platformio.ini
instructions as in Unknown abort() of execution - #4 by maxgerhardt? I also don’t see how only this code could create such an issue on its own, maybe there are effects from other code.
Max,
A few things:
1.
CoolTerm doesn’t give the output you mentioned.
2.
The “normal” terminal in VSCode is “unstoppable” in scrolling over the screen, so it takes some hassle to get this print.
When I examined this output I see that “rotaryEncoderTask.cpp:140” is mentioned. Looking at that line I see a pointer I created:
struct Coder *pCoder;
3.
When I removed the pointer and use the “normal” variable coder - to which the pointer is pointing to - everything works again without any problem at all.
4.
That leads to the unexpected situation that PlatformIO accepts and evaluates the pointer anywhere in the program without problem, the program compiles without hesitation, but crashes when executed.
5.
If you want to see this in action I gladly put the code on GitHub.
Yes that would be great. I suspect you may forgotten to set the pointer to a value (like, pCoder = new Coder;
) or there is a race condition in setting that global variable.
There you are.
I’m curious.
Max,
Looking again at my code; I think you’re right.
I don’t find a statement like: pCoder = &coder;
So, my code has the pointer, but that pointer never points to the address of the variable coder.
Thank you!
