Im now try platformio with visual studio code. I use a wemos d1 mini board. Use rtos.
My code is (in main.cpp):
#include "esp_common.h"
#include "freertos/task.h"
#include "gpio.h"
Any idea?
Regards
Full error message and platformio.ini
Hi maxgerhardt, thanks for your reply.
platformio.ini is
[env:d1_mini]
platform = espressif8266
board = d1_mini
framework = esp8266-rtos-sdk
monitor_speed=115200
Full error message:
Processing d1_mini (platform: espressif8266; board: d1_mini; framework: esp8266-rtos-sdk)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/d1_mini.html
PLATFORM: Espressif 8266 > WeMos D1 R2 and mini
HARDWARE: ESP8266 80MHz 80KB RAM (4MB Flash)
Collected 0 compatible libraries
Linking .pioenvs\d1_mini\firmware.elf
C:\Users\info\.platformio\packages\framework-esp8266-rtos-sdk\lib\libmain.a(app_main.o): In function `uart_rx_one_char':
(.irom0.text+0x3e4): undefined reference to `user_init'
(.irom0.text+0x3fb): undefined reference to `user_init'
C:\Users\info\.platformio\packages\framework-esp8266-rtos-sdk\lib\libmain.a(app_main.o): In function `flash_data_check':
(.irom0.text+0x57c): undefined reference to `user_rf_cal_sector_set'
(.irom0.text+0x6d0): undefined reference to `user_rf_cal_sector_set'
*** [.pioenvs\d1_mini\firmware.elf] Error 1
======================================================= [ERROR] Took 2.43 seconds =======================================================
Thanks!
You’re writing for the ESP8266 RTOS SDK, not Arduino. So your files have to be .c
and you to have a function user_init()
and user_rf_cal_sector_set()
. See the example at platform-espressif8266/examples/esp8266-rtos-sdk-blink at develop · platformio/platform-espressif8266 · GitHub.
Perfect, now build correctly
But now cant work Serial.begin, Serial.print, etc. Also, is available software serial library for this sdk?
Regards
Probably need to look at some of the examples from the ESP8266_RTOS_SDK since you’re still thinking about Arduino-land stuff
i.e. the uart_echo example should give you enough ideas on what to do for serial output… i.e. it looks like you use uart_param_config()
, uart_driver_install()
to set up the UART and uart_write_bytes()
to write to it.
