Weird linker error with esp32
Hi i freshly installed PlatformIO as an plugin into my VSCode. i wanted to try programming an esp32 with the esp-IDF it downloaded the framework fine and installed the toolchain but when i try to build an example programm from esp it throws a linker error:
Processing az-delivery-devkit-v4 (platform: espressif32; board: az-delivery-devkit-v4; framework: espidf)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/az-delivery-devkit-v4.html
PLATFORM: Espressif 32 1.12.0 > AZ-Delivery ESP-32 Dev Kit C V4
HARDWARE: ESP32 240MHz, 520KB RAM, 16MB Flash
 - framework-espidf 3.40000.200303 (4.0.0)
 - tool-cmake 3.16.4
 - tool-ninja 1.7.1
 - toolchain-esp32ulp 1.22851.190618 (2.28.51)
 - toolchain-xtensa32 2.80200.200226 (8.2.0)
Found 0 compatible libraries
Compiling .pio/build/az-delivery-devkit-v4/esp-idf/src/empty.c.o
Generating LD script .pio/build/az-delivery-devkit-v4/esp32_out.ld
Generating partitions .pio/build/az-delivery-devkit-v4/partitions.bin
Compiling .pio/build/az-delivery-devkit-v4/esp-idf/app_trace/app_trace.c.o
Compiling .pio/build/az-delivery-devkit-v4/esp-idf/app_trace/app_trace_util.c.o
Compiling .pio/build/az-delivery-devkit-v4/esp-idf/app_trace/host_file_io.c.o
Compiling and indexing a bunch of stuff...
Indexing .pio/build/az-delivery-devkit-v4/bootloader/esp-idf/xtensa/libxtensa.a
Linking .pio/build/az-delivery-devkit-v4/bootloader.elf
Building .pio/build/az-delivery-devkit-v4/bootloader.bin
esptool.py v2.6
Linking .pio/build/az-delivery-devkit-v4/firmware.elf
/root/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/az-delivery-devkit-v4/esp-idf/esp32/libesp32.a(cpu_start.c.o):(.literal.main_task+0x18): undefined reference to `app_main'
/root/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/az-delivery-devkit-v4/esp-idf/esp32/libesp32.a(cpu_start.c.o): in function `main_task':
/root/.platformio/packages/framework-espidf/components/esp32/cpu_start.c:540: undefined reference to `app_main'
*** [.pio/build/az-delivery-devkit-v4/firmware.elf] Error 1
============================================================================== [FAILED] Took 43.18 seconds ==============================================================================
So… what’s your source code / project? There doesn’t seem to be any file implementing the needed app_main() main entry function?
Is this file literally empty?
I solved it, apparently when creating a new project “app_main” is automatically added to CMake…
I didnt check that since it makes no sense to add that automatically…
