i was working on ESP32 with WIFI and MQTT and that worked.
Very simpel begin , just switch on and off a LED on GPIO pin, by subscribing to the topic and publish on or of.
When i wanted to extend the code with webserver and configured lib dependencies it compiled but when i go to the IP address of the device in a web browser it crashed.
So got in contact with the designer of the library and got as feedback that platformio had some issue’s , he asked me to load the code in Arduino IDE which i did and it compiled and works for days now.
The comment that i got back from him when i asked the differences between Arduino IDE and Platformio i got the following answer:
The conclusion of this is that platformio is not compatible
IMO, PIO is not totally mature yet, and must require more knowledge and skills to manually configure / modify the settings of PIO as well as related libraries, or receiving compiler errors. This currently is the price you have to pay for better debugging environment, if necessary or a must.
We’re still waiting the days PIO can compile as easily as Arduino IDE, without changing anything internally to the libraries’ settings.
You can contribute to PIO by posting an issue in PIO Forum and make that day closer.
It’ll be beneficial if you’d post the link here after having created the PIO Forum issue.
I think the proof is delivered when compiling the same project with Arduino IDE and it works right away.
Anyone tried this code example on a ESP32 Heltec Wifi Kit 32 ?
Can we get a short summary of what Arduino-ESP32 core version you work with in the Arduino IDE (Tools → Board → Board Manager → esp32) and what version of the library you’re working with?
What platformio.ini are you using? What is the “PLATFORM: ESPRESSIF32 x.x.x” version that appears in the console when you press Build?
To have any fair comparison with PlatformIO at all, you would need to select the Heltec WiFi Kit 32 from the Arduino-ESP32 2.0.3 in the Arduino IDE, as that is what the platform-espressif32 5.0.0 is using.
Let me have a quick look on how to integrate the Heltec core version with PlatformIO… there was a topic about this not too long ago.
But wow, what a horrible core to work with. The 0.0.5 and 0.0.6 board package (so, you’re using an outdated version btw.) referenced here are some version of Arduino-ESP32 but with the original version info and all PlatformIO related things (package.json + builder scripts) erased. Not nice.
Can you check whether your program still works with Heltec 0.0.6 version in the Arduino IDE?
Can you check whether your program still works with Arduino-ESP32 2.0.3 in the Arduino IDE?
i am new to the ESP32 in Arduino IDE
I made other project with 2812B led strip with FasLed in platofrmio and no error’s
I use platgormnio because of the JTAG debugging feature , wich can not be done in Arduino IDE or can it?
I’ve see the YT video of Dave’s Garage (Dave Plummer , former MW systems engineer) and he made a couple of video’s about VSC+Platformio and the debugging capabilities.
He also uses the VSC+ platformio as his platform.
So i thought i will build the webserver also with platformio not anticipating this kind of behaviour.
that’s not particularly safe, you’re ignoring Message_lentgh. I don’t know if it’s garuanteed that Message will be NUL-terminated. So cnostructing a String(Message); is dangerous – you should do String m = String(Message, Message_lentgh); and use that.
