I´m trying to test The Webseral-Example from the randomNerds Tutorial (https://randomnerdtutorials.com/esp32-webserial-library/) on a ESP32 but it failes under Platformio while it works in the arduino IDE. I think it is related to the library ESP Async Webserver which contains spaces in his name.
The problem seems to be the linker (see terminal output below).
Here the platformio.ini:
lib_deps = ESP Async WebServer @ ^1.2.3
ayushsharma82/WebSerial @ ^1.4.0
Could it be that it is the same issue as described here: https://github.com/me-no-dev/ESPAsyncWebServer/issues/741, where spaces in the library name caused the issue?
How can I use the library under PlatformIO then? Can I “masked” the spaces in any way?
Regards
PLATFORM: Espressif 32 (6.4.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 @ 3.20011.230801 (2.0.11)
Found 36 compatible libraries
|-- ESP Async WebServer @ 1.2.3
|-- WebSerial @ 1.4.0
|-- AsyncTCP @ 1.1.1
|-- WiFi @ 2.0.0
Compiling .pio/build/esp32dev/src/main.cpp.o
Building .pio/build/esp32dev/bootloader.bin
Generating partitions .pio/build/esp32dev/partitions.bin
Compiling .pio/build/esp32dev/libc59/AsyncTCP/AsyncTCP.cpp.o
Compiling .pio/build/esp32dev/libc32/FS/FS.cpp.o
Compiling .pio/build/esp32dev/libc32/FS/vfs_api.cpp.o
esptool.py v4.5.1
Creating esp32 image...
Merged 1 ELF section
Compiling .pio/build/esp32dev/libaf9/WiFi/WiFi.cpp.o
Compiling .pio/build/esp32dev/libaf9/WiFi/WiFiAP.cpp.o
Compiling .pio/build/esp32dev/libaf9/WiFi/WiFiClient.cpp.o
Compiling .pio/build/esp32dev/libaf9/WiFi/WiFiGeneric.cpp.o
Compiling .pio/build/esp32dev/libaf9/WiFi/WiFiMulti.cpp.o
Compiling .pio/build/esp32dev/libaf9/WiFi/WiFiSTA.cpp.o
Archiving .pio/build/esp32dev/libc59/libAsyncTCP.a
Archiving .pio/build/esp32dev/libc32/libFS.a
Compiling .pio/build/esp32dev/libaf9/WiFi/WiFiScan.cpp.o
Compiling .pio/build/esp32dev/libaf9/WiFi/WiFiServer.cpp.o
Compiling .pio/build/esp32dev/libaf9/WiFi/WiFiUdp.cpp.o
Indexing .pio/build/esp32dev/libc32/libFS.a
Indexing .pio/build/esp32dev/libc59/libAsyncTCP.a
Compiling .pio/build/esp32dev/lib34f/ESP Async WebServer/AsyncEventSource.cpp.o
Compiling .pio/build/esp32dev/lib34f/ESP Async WebServer/AsyncWebSocket.cpp.o
Compiling .pio/build/esp32dev/lib34f/ESP Async WebServer/SPIFFSEditor.cpp.o
Compiling .pio/build/esp32dev/lib34f/ESP Async WebServer/WebAuthentication.cpp.o
Compiling .pio/build/esp32dev/lib34f/ESP Async WebServer/WebHandlers.cpp.o
Compiling .pio/build/esp32dev/lib34f/ESP Async WebServer/WebRequest.cpp.o
Compiling .pio/build/esp32dev/lib34f/ESP Async WebServer/WebResponses.cpp.o
Archiving .pio/build/esp32dev/libaf9/libWiFi.a
Indexing .pio/build/esp32dev/libaf9/libWiFi.a
Compiling .pio/build/esp32dev/lib34f/ESP Async WebServer/WebServer.cpp.o
Compiling .pio/build/esp32dev/libfbd/WebSerial/WebSerial.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/Esp.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/FirmwareMSC.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/HWCDC.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/IPAddress.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/IPv6Address.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/MD5Builder.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/Print.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/Stream.cpp.o
Archiving .pio/build/esp32dev/libfbd/libWebSerial.a
Compiling .pio/build/esp32dev/FrameworkArduino/StreamString.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/Tone.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/USB.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/USBCDC.cpp.o
Indexing .pio/build/esp32dev/libfbd/libWebSerial.a
Compiling .pio/build/esp32dev/FrameworkArduino/USBMSC.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/WMath.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/WString.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/base64.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/cbuf.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-adc.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-bt.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-cpu.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-dac.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-gpio.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-i2c-slave.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-i2c.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-ledc.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-matrix.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-misc.c.o
Archiving .pio/build/esp32dev/lib34f/libESP Async WebServer.a
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-psram.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-rgb-led.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-rmt.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-sigmadelta.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-spi.c.o
Indexing .pio/build/esp32dev/lib34f/libESP Async WebServer.a
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-time.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-timer.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-tinyusb.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-touch.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-uart.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/firmware_msc_fat.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/libb64/cdecode.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/libb64/cencode.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/main.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/stdlib_noniso.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/wiring_pulse.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/wiring_shift.c.o
Archiving .pio/build/esp32dev/libFrameworkArduino.a
Indexing .pio/build/esp32dev/libFrameworkArduino.a
Linking .pio/build/esp32dev/firmware.elf
/home/stefan/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/esp32dev/lib34f/libESP Async WebServer.a(AsyncWebSocket.cpp.o):(.literal._ZN22AsyncWebSocketResponseC2ERK6StringP14AsyncWebSocket+0x18): undefined reference to `SHA1Init'
/home/stefan/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/esp32dev/lib34f/libESP Async WebServer.a(AsyncWebSocket.cpp.o):(.literal._ZN22AsyncWebSocketResponseC2ERK6StringP14AsyncWebSocket+0x1c): undefined reference to `SHA1Update'
/home/stefan/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/esp32dev/lib34f/libESP Async WebServer.a(AsyncWebSocket.cpp.o):(.literal._ZN22AsyncWebSocketResponseC2ERK6StringP14AsyncWebSocket+0x20): undefined reference to `SHA1Final'
/home/stefan/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/esp32dev/lib34f/libESP Async WebServer.a(AsyncWebSocket.cpp.o): in function `AsyncWebSocketResponse::AsyncWebSocketResponse(String const&, AsyncWebSocket*)':
/home/stefan/smb4k/READYNAS3/Public/Elektronik/Arduino/Sketchbook/ESP/ESP32_Webserial/.pio/libdeps/esp32dev/ESP Async WebServer/src/AsyncWebSocket.cpp:1269: undefined reference to `SHA1Init'
/home/stefan/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /home/stefan/smb4k/READYNAS3/Public/Elektronik/Arduino/Sketchbook/ESP/ESP32_Webserial/.pio/libdeps/esp32dev/ESP Async WebServer/src/AsyncWebSocket.cpp:1270: undefined reference to `SHA1Update'
/home/stefan/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /home/stefan/smb4k/READYNAS3/Public/Elektronik/Arduino/Sketchbook/ESP/ESP32_Webserial/.pio/libdeps/esp32dev/ESP Async WebServer/src/AsyncWebSocket.cpp:1271: undefined reference to `SHA1Final'
/home/stefan/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/esp32dev/lib34f/libESP Async WebServer.a(WebAuthentication.cpp.o):(.literal._ZL6getMD5PhtPc+0x4): undefined reference to `mbedtls_md5_starts'
/home/stefan/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/esp32dev/lib34f/libESP Async WebServer.a(WebAuthentication.cpp.o): in function `getMD5(unsigned char*, unsigned short, char*)':
/home/stefan/smb4k/READYNAS3/Public/Elektronik/Arduino/Sketchbook/ESP/ESP32_Webserial/.pio/libdeps/esp32dev/ESP Async WebServer/src/WebAuthentication.cpp:73: undefined reference to `mbedtls_md5_starts'
*** [.pio/build/esp32dev/firmware.elf] Error 1
