I’m trying to get the serial monitor to work with the WeAct Esp32-C3 Core but i don’t get any output.
This is the sketch:
pinMode(8, OUTPUT);
Serial.println("test");
digitalWrite(8, HIGH);
delay(1000);
digitalWrite(8, LOW);
delay(1000);
and platformio.ini:
[env:esp32doit-devkit-v1]
board = esp32-c3-devkitm-1
build_unflags = -std=gnu++11
-std=gnu++17
The led blinks, but there is no output on the serial monitor.
adding
monitor_rts = 0
monitor_dtr = 0
prints this to the serial monitor:
Saved PC:0x420140fa
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd5810,len:0x438
load:0x403cc710,len:0x90c
load:0x403ce710,len:0x2624
entry 0x403cc710
but nothing else and adding:
-D ARDUINO_USB_MODE=1
-D ARDUINO_USB_CDC_ON_BOOT=1
does nothing.
I found this thread: ESP-IDF monitor READ only WeAct Studio board [SOLVED] - Golioth Device Help - Golioth Forums
but i can’t set the menuconfig when using the arduino framework because it uses a precompiled version of esp-idf
Any ideas?
