Could someone please help, I’m trying to compile Marlin (bugfix-1.1.x) in Visual Studio Code but I keep receiving ‘warnings’ and was unsure if they were anything to be concerned about?
> Executing task: C:\Users\Tom\.platformio\penv\Scripts\platformio.exe run <
Warning! `env_default` configuration option in section [platformio] is deprecated and will be removed in the next release! Please use `default_envs` instead
Processing sanguino_atmega1284p (platform: atmelavr; framework: arduino; board: sanguino_atmega1284p)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/sanguino_atmega1284p.html
PLATFORM: Atmel AVR 2.1.0 > Sanguino ATmega1284p (16MHz)
HARDWARE: ATMEGA1284P 16MHz, 16KB RAM, 127KB Flash
- framework-arduino-avr 5.0.0
Converting Marlin.ino
Found 13 compatible libraries
|-- <U8glib-HAL> 0.4
| |-- <Wire> 1.0
| |-- <SPI> 1.0
|-- <LiquidCrystal_I2C>
| |-- <Wire> 1.0
|-- <TMC2130Stepper> 2.5.1
| |-- <SPI> 1.0
|-- <TMC2208Stepper> 0.1.1
|-- <Adafruit NeoPixel> 1.1.3
|-- <30aa480>
| |-- <Wire> 1.0
|-- <Arduino-L6470> 0.8.0
|-- <c1921b4>
| |-- <SPI> 1.0
|-- <Wire> 1.0
|-- <SPI> 1.0
|-- <SoftwareSerial> 1.0
Compiling .pioenvs\sanguino_atmega1284p\src\G26_Mesh_Validation_Tool.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\I2CPositionEncoder.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\M100_Free_Mem_Chk.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\Marlin.ino.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\MarlinSerial.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\Marlin_main.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\Max7219_Debug_LEDs.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\Sd2Card.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\SdBaseFile.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\SdFatUtil.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\SdFile.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\SdVolume.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\blinkm.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\cardreader.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\configuration_store.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\dac_mcp4728.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\digipot_mcp4018.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\digipot_mcp4451.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\emergency_parser.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\endstops.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\fwretract.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\hex_print_routines.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\least_squares_fit.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\leds.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\malyanlcd.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\mesh_bed_leveling.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\neopixel.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\nozzle.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\parser.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\pca9632.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\planner.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\planner_bezier.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\power.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\power_loss_recovery.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\printcounter.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\runout.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\serial.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\servo.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\stepper.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\stepper_dac.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\stepper_indirection.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\stopwatch.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\temperature.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\tmc_util.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\twibus.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\ubl.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\ubl_G29.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\ubl_motion.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\ultralcd.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\utility.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\vector_3.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\src\watchdog.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libfc1\Wire\Wire.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libfc1\Wire\utility\twi.c.o
Compiling .pioenvs\sanguino_atmega1284p\lib6f3\SPI\SPI.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\U8glib.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\U8glibPrint.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\chessengine.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_bitmap.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_circle.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_clip.c.o
Archiving .pioenvs\sanguino_atmega1284p\lib6f3\libSPI.a
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_api.c.o
Archiving .pioenvs\sanguino_atmega1284p\libfc1\libWire.a
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_api_16gr.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_arduino_attiny85_hw_spi.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_arduino_common.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_arduino_fast_parallel.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_arduino_hw_spi.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_arduino_hw_usart_spi.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_arduino_no_en_parallel.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_arduino_parallel.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_arduino_port_d_wr.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_arduino_ssd_i2c.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_arduino_st7920_custom.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_arduino_st7920_hw_spi.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_arduino_st7920_spi.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_arduino_std_sw_spi.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_arduino_sw_spi.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_arduino_t6963.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_arduino_uc_i2c.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_atmega_hw_spi.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_atmega_parallel.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_atmega_st7920_hw_spi.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_atmega_st7920_spi.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_atmega_sw_spi.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_atxmega_hw_spi.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_atxmega_st7920_hw_spi.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_esp32_ssd_i2c_fn.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_i2c.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_io.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_linux_ssd_i2c.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_msp430_hw_spi.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_null.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_psoc5_ssd_hw_parallel.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_raspberrypi_hw_spi.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_raspberrypi_ssd_i2c.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_std_sw_spi.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_stm32duino_hw_spi.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_com_stm32duino_ssd_i2c.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_cursor.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_delay.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_a2_micro_printer.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_flipdisc_2x7.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_gprof.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_ht1632.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_ili9325d_320x240.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_ks0108_128x64.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_lc7981_160x80.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_lc7981_240x128.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_lc7981_240x64.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_lc7981_320x64.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_ld7032_60x32.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_null.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_pcd8544_84x48.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_pcf8812_96x65.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_sbn1661_122x32.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_ssd1306_128x32.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_ssd1306_128x64.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_ssd1306_64x48.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_ssd1309_128x64.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_ssd1322_nhd31oled_bw.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_ssd1322_nhd31oled_gr.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_ssd1325_nhd27oled_bw.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_ssd1325_nhd27oled_bw_new.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_ssd1325_nhd27oled_gr.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_ssd1325_nhd27oled_gr_new.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_ssd1327_96x96_gr.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_ssd1351_128x128.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_ssd1353_160x128.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_st7565_64128n.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_st7565_dogm128.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_st7565_dogm132.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_st7565_lm6059.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_st7565_lm6063.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_st7565_nhd_c12832.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_st7565_nhd_c12864.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_st7687_c144mvgd.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_st7920_128x64.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_st7920_192x32.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_st7920_202x32.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_t6963_128x128.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_t6963_128x64.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_t6963_240x128.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_t6963_240x64.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_tls8204_84x48.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_uc1601_c128032.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_uc1608_240x128.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_uc1608_240x64.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_uc1610_dogxl160.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_uc1611_dogm240.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_uc1611_dogxl240.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_uc1701_dogs102.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_dev_uc1701_mini12864.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_ellipse.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_font.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_font_data.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_line.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_ll_api.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_page.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_pb.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_pb14v1.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_pb16h1.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_pb16h2.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_pb16v1.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_pb16v2.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_pb32h1.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_pb8h1.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_pb8h1f.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_pb8h2.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_pb8h8.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_pb8v1.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_pb8v2.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_pbxh16.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_pbxh24.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_polygon.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_rect.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_rot.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_scale.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_state.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_u16toa.c.o
.piolibdeps\sanguino_atmega1284p\U8glib-HAL_ID1932\src\clib\u8g_rot.c:48:27: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
u8g_dev_t u8g_dev_rot = { u8g_dev_rot_dummy_fn, NULL, NULL };
.piolibdeps\sanguino_atmega1284p\U8glib-HAL_ID1932\src\clib\u8g_rot.c:48:27: note: (near initialization for 'u8g_dev_rot.dev_fn')
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_u8toa.c.o
Compiling .pioenvs\sanguino_atmega1284p\libd9c\U8glib-HAL_ID1932\clib\u8g_virtual_screen.c.o
Compiling .pioenvs\sanguino_atmega1284p\lib2fd\LiquidCrystal_I2C_ID576\LiquidCrystal_I2C.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libfd9\TMC2130Stepper_ID1493\source\SW_SPI.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libfd9\TMC2130Stepper_ID1493\source\TMC2130Stepper.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libfd9\TMC2130Stepper_ID1493\source\TMC2130Stepper_CHOPCONF.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libfd9\TMC2130Stepper_ID1493\source\TMC2130Stepper_COOLCONF.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libfd9\TMC2130Stepper_ID1493\source\TMC2130Stepper_DRV_STATUS.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libfd9\TMC2130Stepper_ID1493\source\TMC2130Stepper_GCONF.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libfd9\TMC2130Stepper_ID1493\source\TMC2130Stepper_IHOLD_IRUN.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libfd9\TMC2130Stepper_ID1493\source\TMC2130Stepper_PWMCONF.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libf9d\TMC2208Stepper\source\TMC2208Stepper.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libf9d\TMC2208Stepper\source\TMC2208Stepper_CHOPCONF.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libf9d\TMC2208Stepper\source\TMC2208Stepper_DRVSTATUS.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libf9d\TMC2208Stepper\source\TMC2208Stepper_GCONF.cpp.o
Archiving .pioenvs\sanguino_atmega1284p\lib2fd\libLiquidCrystal_I2C_ID576.a
Compiling .pioenvs\sanguino_atmega1284p\libf9d\TMC2208Stepper\source\TMC2208Stepper_OTP_READ.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libf9d\TMC2208Stepper\source\TMC2208Stepper_PWMCONF.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\lib435\Adafruit NeoPixel_ID28\Adafruit_NeoPixel.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\lib435\Adafruit NeoPixel_ID28\esp8266.c.o
Compiling .pioenvs\sanguino_atmega1284p\lib4f5\30aa480\LiquidTWI2.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\lib7f7\Arduino-L6470\L6470.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\libdab\c1921b4\TMC26XStepper.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\lib5c1\SoftwareSerial\SoftwareSerial.cpp.o
Archiving .pioenvs\sanguino_atmega1284p\libFrameworkArduinoVariant.a
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\CDC.cpp.o
Archiving .pioenvs\sanguino_atmega1284p\libfd9\libTMC2130Stepper_ID1493.a
In file included from .piolibdeps\sanguino_atmega1284p\Arduino-L6470\src\L6470.cpp:15:0:
.piolibdeps\sanguino_atmega1284p\Arduino-L6470\src\L6470.h: In static member function 'static uint8_t L64XXHelper::transfer(uint8_t,
_pin_t)':
.piolibdeps\sanguino_atmega1284p\Arduino-L6470\src\L6470.h:279:71: warning: no return statement in function returning non-void [-Wreturn-type]
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\HardwareSerial.cpp.o
static inline uint8_t transfer(uint8_t data, const _pin_t ss_pin) { }
_pin_t, uint8_t)':
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\HardwareSerial0.cpp.o
.piolibdeps\sanguino_atmega1284p\Arduino-L6470\src\L6470.h:280:101: warning: no return statement in function returning non-void [-Wreturn-type]
static inline uint8_t transfer(uint8_t data, const _pin_t ss_pin, const uint8_t chain_position) { }
Archiving .pioenvs\sanguino_atmega1284p\libf9d\libTMC2208Stepper.a
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\HardwareSerial1.cpp.o
.piolibdeps\sanguino_atmega1284p\Arduino-L6470\src\L6470.h: In static member function 'static uint8_t L64XX::transfer_noop(uint8_t, _pin_t)':
.piolibdeps\sanguino_atmega1284p\Arduino-L6470\src\L6470.h:399:76: warning: no return statement in function returning non-void [-Wreturn-type]
static inline uint8_t transfer_noop(uint8_t data, const _pin_t ss_pin) { }
.piolibdeps\sanguino_atmega1284p\Arduino-L6470\src\L6470.h: In static member function 'static uint8_t L64XX::chain_transfer_noop(uint8_t, _pin_t, uint8_t)':
.piolibdeps\sanguino_atmega1284p\Arduino-L6470\src\L6470.h:400:112: warning: no return statement in function returning non-void [-Wreturn-type]
static inline uint8_t chain_transfer_noop(uint8_t data, const _pin_t ss_pin, const uint8_t chain_position) { }
.piolibdeps\sanguino_atmega1284p\Arduino-L6470\src\L6470.cpp: In member function 'void L64XX::setMicroSteps(int16_t)':
.piolibdeps\sanguino_atmega1284p\Arduino-L6470\src\L6470.cpp:141:38: warning: suggest parentheses around operand of '!' or change '|' to '||' or '!' to '~' [-Wparentheses]
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\HardwareSerial2.cpp.o
SetParam(L6470_STEP_MODE, !SYNC_EN | stepVal | SYNC_SEL_1);
Archiving .pioenvs\sanguino_atmega1284p\lib435\libAdafruit NeoPixel_ID28.a
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\HardwareSerial3.cpp.o
Archiving .pioenvs\sanguino_atmega1284p\lib4f5\lib30aa480.a
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\IPAddress.cpp.o
Archiving .pioenvs\sanguino_atmega1284p\lib7f7\libArduino-L6470.a
Archiving .pioenvs\sanguino_atmega1284p\lib5c1\libSoftwareSerial.a
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\PluggableUSB.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\Print.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\Stream.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\Tone.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\USBCore.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\WInterrupts.c.o
Archiving .pioenvs\sanguino_atmega1284p\libdab\libc1921b4.a
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\WMath.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\WString.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\abi.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\hooks.c.o
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\main.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\new.cpp.o
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\wiring.c.o
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\wiring_analog.c.o
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\wiring_digital.c.o
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\wiring_pulse.S.o
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\wiring_pulse.c.o
Compiling .pioenvs\sanguino_atmega1284p\FrameworkArduino\wiring_shift.c.o
Archiving .pioenvs\sanguino_atmega1284p\libFrameworkArduino.a
Archiving .pioenvs\sanguino_atmega1284p\libd9c\libU8glib-HAL_ID1932.a
Linking .pioenvs\sanguino_atmega1284p\firmware.elf
Building .pioenvs\sanguino_atmega1284p\firmware.hex
Checking size .pioenvs\sanguino_atmega1284p\firmware.elf
RAM: [=== ] 28.3% (used 4629 bytes from 16384 bytes)
Flash: [========= ] 94.3% (used 122586 bytes from 130048 bytes)
=================================================== [SUCCESS] Took 32.80 seconds ===================================================
Environment Status Duration
megaatmega2560 IGNORED
megaatmega1280 IGNORED
at90USB1286_CDC IGNORED
at90USB1286_DFU IGNORED
melzi IGNORED
melzi_optiboot IGNORED
rambo IGNORED
sanguino_atmega644p IGNORED
sanguino_atmega1284p SUCCESS 00:00:32.805
teensy20 IGNORED
==================================================== 1 succeeded in 00:00:32.805 ====================================================
