Hello, I have a problem with VSCODE - PLATFORMIO. It does not load the codes neither ESP32 nor ARDUINOS - ATMEGA328P.
ESP32 only loads the typical “Blink”. But when you put a library like “Adafruit_SSD1306.h” + “Adafruit_GFX.h” it gives an error.
(The same codes are loaded without problems with the Arduino IDE).
For the serial port of VSCODE it indicates the following error message for the serial port that is repeated continuously:
ELF file SHA256: 0000000000000000
Backtrace: 0x4000c46c:0x3ffb1f50 0x400d1629:0x3ffb1f60 0x400d0d14:0x3ffb1f80 0x400d3716:0x3ffb1fb0 0x40086a75:0x3ffb1fd0
Rebooting…
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP: 0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5828
entry 0x400806a8
Guru Meditation Error: Core 1 panic’ed (StoreProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x4000c46c PS : 0x00060030 A0 : 0x800d162c A1 : 0x3ffb1f50
A2 : 0x00000000 A3 : 0x00000000 A4 : 0x00000400 A5 : 0x00000000
A6 : 0x00000000 A7 : 0x00000040 A8 : 0x00000020 A9 : 0x80000020
A10 : 0x00000008 A11 : 0x00000001 A12 : 0x00000005 A13 : 0x00000020
A14 : 0x00000020 A15 : 0x00000000 SAR : 0x00000000 EXCCAUSE: 0x0000001d
EXCVADDR: 0x00000000 LBEG : 0x4000c46c LEND : 0x4000c477 LCOUNT : 0x0000003f
I HAVE TRIED EVERYTHING I KNOW. THANKS FOR THE HELP!!!
