At first, I’m aware of numerous github issues similiar to this. But they seem to be outdated (2020 as far as I’m concerned), also none of these solutions seem to work for me.
OS: Win11 21H2
VSCode: 1.70
PlatformIO: 2.5.1
When I want to install the extension, this error occurs:
File "C:\Users\Max\.platformio\.cache\tmp\get-platformio-1.1.2.py", line 69, in <module>
main()
File "C:\Users\Max\.platformio\.cache\tmp\get-platformio-1.1.2.py", line 61, in main
bootstrap()
File "C:\Users\Max\.platformio\.cache\tmp\get-platformio-1.1.2.py", line 47, in bootstrap
pioinstaller.__main__.main()
File "C:\Users\Max\.platformio\.cache\tmp\.piocore-installer-01z5dm8y\tmpjafvn6w6\pioinstaller.zip\pioinstaller\__main__.py", line 133, in main
File "C:\Users\Max\.platformio\.cache\tmp\.piocore-installer-01z5dm8y\tmpjafvn6w6\pioinstaller.zip\click\core.py", line 1128, in __call__
File "C:\Users\Max\.platformio\.cache\tmp\.piocore-installer-01z5dm8y\tmpjafvn6w6\pioinstaller.zip\click\core.py", line 1053, in main
File "C:\Users\Max\.platformio\.cache\tmp\.piocore-installer-01z5dm8y\tmpjafvn6w6\pioinstaller.zip\click\core.py", line 1637, in invoke
File "C:\Users\Max\.platformio\.cache\tmp\.piocore-installer-01z5dm8y\tmpjafvn6w6\pioinstaller.zip\click\core.py", line 1395, in invoke
File "C:\Users\Max\.platformio\.cache\tmp\.piocore-installer-01z5dm8y\tmpjafvn6w6\pioinstaller.zip\click\core.py", line 754, in invoke
File "C:\Users\Max\.platformio\.cache\tmp\.piocore-installer-01z5dm8y\tmpjafvn6w6\pioinstaller.zip\click\decorators.py", line 26, in new_func
File "C:\Users\Max\.platformio\.cache\tmp\.piocore-installer-01z5dm8y\tmpjafvn6w6\pioinstaller.zip\pioinstaller\__main__.py", line 61, in cli
File "C:\Users\Max\.platformio\.cache\tmp\.piocore-installer-01z5dm8y\tmpjafvn6w6\pioinstaller.zip\pioinstaller\core.py", line 88, in install_platformio_core
File "C:\Users\Max\.platformio\.cache\tmp\.piocore-installer-01z5dm8y\tmpjafvn6w6\pioinstaller.zip\pioinstaller\core.py", line 70, in install_platformio_core
File "C:\Users\Max\.platformio\.cache\tmp\.piocore-installer-01z5dm8y\tmpjafvn6w6\pioinstaller.zip\pioinstaller\core.py", line 98, in _install_platformio_core
File "C:\Users\Max\.platformio\.cache\tmp\.piocore-installer-01z5dm8y\tmpjafvn6w6\pioinstaller.zip\pioinstaller\penv.py", line 71, in create_core_penv
File "C:\Users\Max\.platformio\.cache\tmp\.piocore-installer-01z5dm8y\tmpjafvn6w6\pioinstaller.zip\pioinstaller\penv.py", line 141, in init_state
File "C:\Users\Max\.platformio\python3\lib\subprocess.py", line 424, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File "C:\Users\Max\.platformio\python3\lib\subprocess.py", line 528, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['C:\\Users\\Max\\.platformio\\penv\\Scripts\\python.exe', '-c', "import sys; version=sys.version_info; print('%d.%d.%d'%(version[0],version[1],version[2]))"]' returned non-zero exit status 101.
-> Installer version: 1.1.2
Platform: Windows-10
Python version: 3.9.10 (tags/v3.9.10:f2f3f53, Jan 17 2022, 15:14:21) [MSC v.1929 64 bit (AMD64)]
Python path: C:\Users\Max\.platformio\python3\python.exe
Creating a virtual environment at C:\Users\Max\.platformio\penv
at c:\Users\Max\.vscode\extensions\platformio.platformio-ide-2.5.1-win32-x64\node_modules\platformio-node-helpers\dist\index.js:1:5308
at ChildProcess.o (c:\Users\Max\.vscode\extensions\platformio.platformio-ide-2.5.1-win32-x64\node_modules\platformio-node-helpers\dist\index.js:1:4691)
at ChildProcess.emit (node:events:390:28)
at ChildProcess.emit (node:domain:475:12)
at maybeClose (node:internal/child_process:1064:16)
at Process.ChildProcess._handle.onexit (node:internal/child_process:301:5)
How can I fix this?
