I have a board ESP32S3 with 8MB PSRAM (N4R8), on Arduino IDE, when I choose QSPI, in PSRAM selection, the PSRAM not detected, I have to choose OPI so the PSRAM detected and read as 8MB, I couldn’t find a way to change that in the platformIO, all the supported boards are 2MB PSRAM, I tried to change the memory type in the board’s .json file from qio to opi , but nothing works, How to change the PSRAM type to be detected by the platformIO? any advise please?
Set memory_type accordingly, check out Enable OPI PSRAM and 16MB QIO80MHz of FLASH - #2 by maxgerhardt.
Thanks for your replay, I already tried this, when I added any of theses lines(or all of them) into *.ini file, ESP crashes
board_build.arduino.memory_type = qio_opi
board_build.f_flash = 80000000L
board_build.flash_mode = qio
Can you screenshot the Arduino IDE → Tools menu with which it works in the Arduino IDE?
What’s the used Arduino-ESP32 version? Tools->Boards->Board Manager → esp32.
No, I want to know what Arduino-ESP32 core version is used. For example, 2.0.7.
Make sure the same core version is used in PlatformIO, e.g. by using a CLI → pio pkg update -g -p espressif32.
Are you testing this with the minimalist possible code?
void setup() { Serial.begin(115200); }
void loop() { Serial.println("test"); delay(1000); }
it work just fine with Arduino IDE, I’m using PlatformIO with VSCode, which what I have issue with, the PSRAM not detected by the ESP32, I have another board with 2MB PSRAM, which work just fine with the same code, the *.ini file as below, i commented the last two line so the code works, otherwise, it crashes :
[common]
-DFZ_WITH_ASYNCSRV
-DBOARD_HAS_PSRAM
-mfix-esp32-psram-cache-issue
;board_build.arduino.memory_type = qio_opi
;board_build.flash_mode = qio
it is the same version, I tried minimalist possible code, still crashes
