So, I have code for an arduino here.
I already know the edit and that it should work.
There’s just one problem with Platformio:
After I edit the code, press CTRL S to save and then click on compile/upload, the code kind off gets changed back to the original, just for it to give me that nifty error message.
As if I were to edit something in Photoshop, press CTRL Z a few times and then save the picture.
Here’s the output:
|-- <SmoothThermistor> 1.3.1
|-- <ClickEncoder> 0.0.0-alpha+sha.9337a0c46c
|-- <EEPROM> 2.0
|-- <PID> 1.2.1
|-- <TimerOne> 1.1
|-- <U8glib> 1.19.1
Compiling .pio\build\uno\src\main.cpp.o
Compiling .pio\build\uno\libcf7\SmoothThermistor\SmoothThermistor.cpp.o
Compiling .pio\build\uno\libc51\ClickEncoder\ClickEncoder.cpp.o
Archiving .pio\build\uno\lib444\libEEPROM.a
In file included from .pio\libdeps\uno\ClickEncoder\ClickEncoder.cpp:12:0:
.pio\libdeps\uno\ClickEncoder\ClickEncoder.h: In constructor 'ClickEncoder::ClickEncoder(int8_t, int8_t, int8_t, uint8_t, bool)':
.pio\libdeps\uno\ClickEncoder\ClickEncoder.h:165:8: warning: 'ClickEncoder::buttonHeldEnabled' will be initialized after [-Wreorder]
bool buttonHeldEnabled;
.pio\libdeps\uno\ClickEncoder\ClickEncoder.h:158:8: warning: 'bool ClickEncoder::accelerationEnabled' [-Wreorder]
bool accelerationEnabled;
Compiling .pio\build\uno\lib4e7\PID\PID_v1.cpp.o
.pio\libdeps\uno\ClickEncoder\ClickEncoder.cpp:44:1: warning: when initialized here [-Wreorder]
ClickEncoder::ClickEncoder(int8_t A, int8_t B, int8_t BTN, uint8_t stepsPerNotch, bool active)
.pio\libdeps\uno\ClickEncoder\ClickEncoder.h:158:8: warning: 'ClickEncoder::accelerationEnabled' will be initialized after [-Wreorder]
.pio\libdeps\uno\ClickEncoder\ClickEncoder.h:154:20: warning: 'volatile int16_t ClickEncoder::delta' [-Wreorder]
volatile int16_t delta;
.pio\libdeps\uno\ClickEncoder\ClickEncoder.h:163:19: warning: 'ClickEncoder::button' will be initialized after [-Wreorder]
volatile Button button;
.pio\libdeps\uno\ClickEncoder\ClickEncoder.h:156:20: warning: 'volatile uint8_t ClickEncoder::steps' [-Wreorder]
volatile uint8_t steps;
.pio\libdeps\uno\ClickEncoder\ClickEncoder.h:156:20: warning: 'ClickEncoder::steps' will be initialized after [-Wreorder]
.pio\libdeps\uno\ClickEncoder\ClickEncoder.h:150:10: warning: 'int8_t ClickEncoder::pinA' [-Wreorder]
int8_t pinA;
.pio\libdeps\uno\ClickEncoder\ClickEncoder.h: In constructor 'ClickEncoder::ClickEncoder(int8_t, bool)':
.pio\libdeps\uno\ClickEncoder\ClickEncoder.cpp:74:1: warning: when initialized here [-Wreorder]
ClickEncoder::ClickEncoder(int8_t BTN, bool active)
.pio\libdeps\uno\ClickEncoder\ClickEncoder.h:167:22: warning: 'ClickEncoder::analogInput' will be initialized after [-Wreorder]
bool analogInput = false;
int8_t pinA;
.pio\libdeps\uno\SmoothThermistor\src\SmoothThermistor.cpp:53:2: error: invalid preprocessing directive #IF
#IF !defined(ESP32) || !defined(ESP8266)
.pio\libdeps\uno\SmoothThermistor\src\SmoothThermistor.cpp:55:2: error: invalid preprocessing directive #ENDIF
#ENDIF
src\main.cpp: In function 'void viewSettings()':
src\main.cpp:560:31: warning: comparison with string literal results in unspecified behaviour [-Waddress]
if (isEditing && topText == "") {
*** [.pio\build\uno\libcf7\SmoothThermistor\SmoothThermistor.cpp.o] Error 1
===================================================================================================== [FAILED] Took 4.55 seconds =====================================================================================================
The terminal process "C:\Users\minec\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload'" terminated with exit code: 1.
