New user : using VSCode / PlatformIO
PIO 5.0.4
VSC 1.52.1
Using Project Wizard to Create new …
Enter Project name, DOIT ESP32 …, Arduino
Gives “could not initialize project” error
“Server error: {“type”:“FileNotFoundError”,“args”:[2,“The system cannot find the file specified”],“message”:”[WinError 2] The system cannot find the file specified: ‘C:\\Users\\Dell\\Documents\\PlatformIO\\Projects\\test4’"}
Before this, it complained, unable to find “PlatformIO”
So created it manually
Then it complained, unable to find “projects”
So I created it manually
Etc etc
But it seems it is unable to create files for some reason ?
So I have started VSC with Admin rights - but no change
Any suggestions please ?
This is error once I have manually created “projects\test4” and then try to create a new project called “test4”
PIO Core Call Error:
The current working directory C:\Users\Dell\Documents\PlatformIO\Projects\test4 will be used for the project.
The next files/directories have been created in C:\Users\Dell\Documents\PlatformIO\Projects\test4
File "c:\users\dell\.platformio\penv\lib\site-packages\platformio\__main__.py", line 109, in main
File "c:\users\dell\.platformio\penv\lib\site-packages\click\core.py", line 829, in __call__
File "c:\users\dell\.platformio\penv\lib\site-packages\click\core.py", line 782, in main
rv = self.invoke(ctx)
File "c:\users\dell\.platformio\penv\lib\site-packages\platformio\commands\__init__.py", line 44, in invoke
return super(PlatformioCLI, self).invoke(ctx)
File "c:\users\dell\.platformio\penv\lib\site-packages\click\core.py", line 1259, in invoke
File "c:\users\dell\.platformio\penv\lib\site-packages\click\core.py", line 1066, in invoke
File "c:\users\dell\.platformio\penv\lib\site-packages\click\core.py", line 610, in invoke
return callback(*args, **kwargs)
File "c:\users\dell\.platformio\penv\lib\site-packages\click\decorators.py", line 21, in new_func
File "c:\users\dell\.platformio\penv\lib\site-packages\platformio\commands\project.py", line 179, in project_init
init_base_project(project_dir)
File "c:\users\dell\.platformio\penv\lib\site-packages\platformio\commands\project.py", line 227, in init_base_project
config.save()
File "c:\users\dell\.platformio\penv\lib\site-packages\platformio\project\config.py", line 468, in save
with open(path or self.path, "w+") as fp:
FileNotFoundError: [Errno 2] No such file or directory: 'C:\\Users\\Dell\\Documents\\PlatformIO\\Projects\\test4\\platformio.ini'
\n============================================================\r\n\r\nAn unexpected error occurred. Further steps:\r\n\r\n* Verify that you have the latest version of PlatformIO using\r\n `pip install -U platformio` command\r\n\r\n* Try to find answer in FAQ Troubleshooting section\r\n https://docs.platformio.org/page/faq.html\r\n\r\n* Report this problem to the developers\r\n https://github.com/platformio/platformio-core/issues\r\n\r\n
