When building a project in VSCode 1.18 the build task is active, also when building itself is ok.
The CPU load is 50%, so the computer becomes very slow.
When uploading, the build process is ok, but also there the task is running and needs to stop manually.
Update: this happens only on my MacBookPro15, on my old one there are no problems
Yes, the update (Core and Platforms) is in the moment terrible slow also on Atom. I think that is also a reason for the timeouts. Meanwhile I have the Task-Problem also on my other Mac, it seems it comes with an update, but I don’t now which one (VSCode, C++ Tools, Pio ???).
Users of the macOS version should not update to High Sierra 10.13.2 when you want to avoid problems with terminal. The guys from VSC are looking for a solution.
