This is the upload:
Checking size .pio\build\BIGTREE_E3_RRF\firmware.elf
RAM: [= ] 6.0% (used 7928 bytes from 131072 bytes)
Flash: [= ] 8.8% (used 92376 bytes from 1048576 bytes)
Configuring upload protocol…
AVAILABLE: dfu, jlink, stlink
Uploading .pio\build\BIGTREE_E3_RRF\firmware.elf
xPack OpenOCD, x86_64 Open On-Chip Debugger 0.10.0+dev-00378-ge5be992df (2020-06-26-09:29)
Licensed under GNU GPL v2
For bug reports, read
OpenOCD: Bug Reporting
debug_level: 1
hla_swd
none separate
xPSR: 0x01000000 pc: 0x00010100 msp: 0x464c457c
** Programming Started **
** Programming Finished **
** Verify Started **
** Verified OK **
** Resetting Target **
shutdown command invoked
======================================================================== [SUCCESS] Took 193.86 seconds ========================================================================
This is what i get when i start debug:
Executing task: C:\Users\Phillip.platformio\penv\Scripts\platformio.exe debug <
Processing simulator_linux_debug (platform: native; framework: )
-----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via -v, --verbose option
Der Befehl ““CC”” ist entweder falsch geschrieben oder
konnte nicht gefunden werden.
CalledProcessError: Command ‘“CC” -D__MARLIN_FIRMWARE__ -DNDEBUG -D__PLAT_NATIVE_SIM__ -DU8G_HAL_LINKS -D__MARLIN_DEPS__ -w -dM -E -x c++ buildroot/share/PlatformIO/scripts/common-dependencies.h’ returned non-zero exit status 1.:
File “C:\Users\Phillip.platformio\penv\lib\site-packages\platformio\builder\main.py”, line 179:
env.SConscript(item, exports=“env”)
File “C:\Users\Phillip.platformio\packages\tool-scons\scons-local-4.3.0\SCons\Script\SConscript.py”, line 597:
File “C:\Users\Phillip.platformio\packages\tool-scons\scons-local-4.3.0\SCons\Script\SConscript.py”, line 285:
exec(compile(scriptdata, scriptname, ‘exec’), call_stack[-1].globals)
File “D:\Projects\ROBODOS_FEB22\Giebler\Downloads\Marlin-tmc26x_cs_STM32F4\Marlin-tmc26x_cs\buildroot\share\PlatformIO\scripts\common-dependencies.py”, line 247:
apply_features_config()
File “D:\Projects\ROBODOS_FEB22\Giebler\Downloads\Marlin-tmc26x_cs_STM32F4\Marlin-tmc26x_cs\buildroot\share\PlatformIO\scripts\common-dependencies.py”, line 133:
if not env.MarlinFeatureIsEnabled(feature):
File “C:\Users\Phillip.platformio\packages\tool-scons\scons-local-4.3.0\SCons\Util.py”, line 742:
File “D:\Projects\ROBODOS_FEB22\Giebler\Downloads\Marlin-tmc26x_cs_STM32F4\Marlin-tmc26x_cs\buildroot\share\PlatformIO\scripts\common-dependencies.py”, line 216:
load_marlin_features()
File “D:\Projects\ROBODOS_FEB22\Giebler\Downloads\Marlin-tmc26x_cs_STM32F4\Marlin-tmc26x_cs\buildroot\share\PlatformIO\scripts\common-dependencies.py”, line 204:
define_list = run_preprocessor(env)
File “D:\Projects\ROBODOS_FEB22\Giebler\Downloads\Marlin-tmc26x_cs_STM32F4\Marlin-tmc26x_cs\buildroot\share\PlatformIO\scripts\preprocessor.py”, line 42:
define_list = subprocess.check_output(cmd, shell=True).splitlines()
File “C:\Users\Phillip.platformio\python3\lib\subprocess.py”, line 424:
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File “C:\Users\Phillip.platformio\python3\lib\subprocess.py”, line 528:
raise CalledProcessError(retcode, process.args,
================================================================================= [FAILED] Took 1.54 seconds =================================================================================
Environment Status Duration
simulator_linux_debug FAILED 00:00:01.540
============================================================================ 1 failed, 0 succeeded in 00:00:01.540 ============================================================================The terminal process “C:\Users\Phillip.platformio\penv\Scripts\platformio.exe ‘debug’” terminated with exit code: 1.
I am greatful for help.
