Hi, in the terminal output I see this when building:
But I can’t seem to find where to set this in settings. I tried settings:c_cpp logging lever to “information” but this didn’t seem to have any affect.
Does anyone know how to set visual studio code builds to verbose?
Thanks
The project tasks give you a Build and Verbose Build option, same for upload. The “Build” invokes pio run and thus you get the message that you can enable verbose mode by running pio run -v, and “Verbose Build” does run it with pio run -v so this message doesn’t appear.
In short: The -v option refers to the PlatformIO CLI usage (which the buld tasks invoke), just use the “Verbose” version of the task to get it.
Outstanding! So simple. Thanks!
