When using just PlatformIO I can’t reproduce the problem. If I clone your repo and add the data
folder from your previous repo GitHub - Aleph-Design/Test-IoT-Gadget and do a Uplaod filesystem + Upload + Monitor, the system behaves as expected
0:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
ets Jun 8 2016 00:22:57
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5828
entry 0x400806a8
SPIFFS available!
---Dir: /:
File name: /NotoSansBold-15.vlw
File name: /NotoSansBold-36.vlw
File name: /SansSerif36.vlw
Font file /NotoSansBold-36 not found!
--- exit ---
Note that you get the
error because your code does
pTft->loadFont("/NotoSansBold-36", SPIFFS);
but should be donig
pTft->loadFont("NotoSansBold-36", SPIFFS);
since the loadFont()
function automatically adds the /
prefix.
I then tested this on the Arduino IDE with the GitHub - lorol/arduino-esp32fs-plugin: Arduino plugin for uploading files to ESP32 file system plugin, creating an empty sektch, saving it, then going into that sketch’s folder (C:\Users\Max\Documents\Arduino\sketch_aug10a
in my case), copying the data
folder into it, selected “DOIT ESP32 DEVKIT V1” as my board, made sure Tools → Port is correct and also Tools → Partition Scheme was set to “Default 4MB SPIFFS” (this must be the same as the PlatformIO sketch is using, but for this board there was no other choice). Then I choose Tools → ESP32 Sketch Data Upload → SPIFFS
And after a succesfull upload
I restarted the PIO device monitor
--- Miniterm on COM4 115200,8,N,1 ---
entry 0x400806a8
SPIFFS available!
---Dir: /:
--- exit ---
to find that all the files are still there as expected.
So I can only guess what’s wrong here – maybe you are using a different Plugin, maybe a different version of it, maybe you’re having a different ESP32 core version installed that differs from PlatformIO’s (1.0.6). But as-is, I can’t reproduce the behavior you see.
EDIT: Corrected a mistake in the text where I selected the wrong board in the Arduino IDE. Selecting “ESP32 Dev Kit” while PlatformIO uses board = esp32doit-devkit-v1
will cause an error, in my case when I erase the flash, only upload the firmware via PlatformIO and the data via the Arduino IDE, the SPIFFS partition failed to be mounted.
