Versions of arduino-esp32 and esp-idf
I’m trying track a complex issue in my code. For this i need to check different versions of arduino-esp32 and esp-idf cores. How does platformio control which version is used?
In platform.json there are version numbers, but i can’t find corresponding version numbers in the github repos of arduino-esp32 and esp-idf?
 "framework-arduinoespressif32": {
      "type": "framework",
      "optional": true,
      "version": "~2.10000.0"
    "framework-espidf": {
      "optional": true,
      "version": "~3.30101.0"
@ivankravets could you give me a pointer to how this works, please? thx.
See Espressif 32 — PlatformIO latest documentation
https://github.com/platformio/platform-espressif32/blob/feature/stage/platform.json#L48
If you need to specify a commit, use https://github.com/espressif/arduino-esp32.git#commit-sha1. More details Redirecting...
@ivankravets I know how this works in general. But can’t find out which arduino-esp32 commit is grabbed by the version statement. How is mapping done between this version number and a certain commit / release of the arduino-esp32 library?
I had a similar issue and I solved it this way:
[env:esp32git110]
platform=espressif32@1.1.0
board=esp32dev
Is this what you were looking for?
I know how to load a certain version of the arduino-esp32 library. My question is which library version is grabbed by the statement “~2.10000.0”?
It’s 1.0.0 release, see Y from X.Y.Z in version => GitHub - espressif/arduino-esp32 at 1.0.0
